18 Pages V  « < 13 14 15 16 17 > »
> Stef's 7AFTE Tech/Project, First Dyno run pg16
post Apr 8, 2009 - 8:24 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE (d0w0rkS0n @ Apr 8, 2009 - 2:09 PM) *
but my *smaller* vaccum hose is still connecting the Valve cover to the Intake Manfiold.
ahh... I didn't know that, that might be your whole problem for the reasons mentioned above.
The crankcase should not be hooked up to the intake manifold or anything that sees positive pressure at any time.
I <3 Dustin---07/16/06
post Apr 9, 2009 - 1:44 AM
6strngs
Joined May 12, '06
From Wilmington, NC
you should just weld a bung to the oil pan and re-route all the oil blowing out of the pcv back into your oil pan biggrin.gif
post Apr 9, 2009 - 7:10 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
haha... yea I've thought of that, the 3rd gen 3S has a stock catch can that reroutes it back into the block.
New compression test results....but first the old results for comparison
First compression test--216,181 mi
cyl-1----cyl-2----cyl-3----cyl-4
-160-----160-----165-----60-
Second--216,234 mi
-160-----160-----165-----75-
Third--216,905 mi
-190-----180-----180-----90-
Still going in the right direction at least.
post Apr 9, 2009 - 8:39 AM
d0w0rkS0n
Joined Jun 10, '08
From Virginia beach
QUOTE (hurley97 @ Apr 9, 2009 - 8:10 AM) *
Second--216,234 mi
Third--216,905 mi
haha its trying to get back up there. thats impressive that its *rebuilding itself* in a way. im guessing youve just been taking it easy? or is that with a little harsh driving.
and on the note of the vaccum hose... i guess ill be taking that off tonight. and just plug the intake manifold.
1994 Toyota Celica ST Turbo
1991 Toyota MR2
MySpace
post Apr 9, 2009 - 10:29 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
Actually I've been beating the hell out of it. Since I reconnected the intercooler pump and it felt so much better that just made me want to drive faster.
post Apr 9, 2009 - 12:43 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE (hurley97 @ Apr 9, 2009 - 8:29 AM) *
have you done a wet compression test or a leak-down test to be sure that the low compression isn't caused by something simpler to fix than piston rings?
post Apr 11, 2009 - 3:52 PM
d0w0rkS0n
Joined Jun 10, '08
From Virginia beach
alright i set up my pcv system like you stef. and disconnected my smaller vacuum hose and just plugged both of the holes.
ran the car yesterday, full boost a couple times, got home and popped the hood....
i was excited lol.
i used to not be able to hit boost at all without seeing some oil under the hood!
Thanks!
-Allen
p.s. post pics when you get your Non-recirculating Breather/Overflow tank hooked up. i wanna see
1991 Toyota MR2
MySpace
post Jun 13, 2009 - 7:16 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
So I began the tear down this afternoon around 4pm when work was over. About two hours later this is what we found...
A few chunks of piston in the oil pan
and the piston from cyl #4
top of the piston, the rest of them looked much much cleaner
kind of hard to tell but the top compression ring is warped
you can see it better here
and the cylinders look fine
cylinder 1
cylinder 2
cylinder 3
cylinder 4
So I'm relieved to find the problem and not too much damage to anything else. Tomorrow is clean and re-assemble. Should be fun biggrin.gif
post Jun 14, 2009 - 6:38 AM
NICE!
damn steff you HAMMERED that ringland with detonation to break it all apart like that.
post Jun 14, 2009 - 9:40 AM
laff09
Joined Jul 28, '06
From Delaware
Nice, I spent about 4 hours last night getting plugs out of the block LOL. Looks like you did a number on that ringland. If you get a chance while your re-honing the cylinder -- see if the tech has any idea what kinda of abrasive material the hone is, if ya get a chance wink.gif
post Jun 15, 2009 - 5:28 PM
FunkySR
Joined Apr 22, '07
From Buckinghamshire, UK
Damn girl. I ditched my catch can completely on my 7a. PCV valve hooked to intake manifold. Second nipple on intake manifold blanked and nipple on valve cover attached to a breather filter. biggrin.gif
post Jun 26, 2009 - 8:35 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
We got the new wastegate on last week, I just haven't had a chance to post any pictures yet,
Manny and Dustin took everything apart while I was at work, Manny welded everything together, and I went on my day off to help Manny put everything back together.
Here's the pics from out of the box followed by some from the install process. I still have to get some finished pics, maybe later today...
QUOTE (hurley97 @ Mar 11, 2009 - 12:22 AM) *
It's a Tial .5 bar (about 7psi) 38mm MV-S V-Band Wastegate. It's their new smaller sized wastegate.
I got it from HS Tuning, it was the best price I could find and their customer service was excellent.
post Jun 26, 2009 - 8:56 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
this is the best looking 7AFTE here... I just love your engine bay.
post Jun 26, 2009 - 9:15 AM
a few pics i took during the process:
post Jun 26, 2009 - 11:02 AM
TRD_Ian
Joined Aug 19, '08
From New Brunswick
nice work!, that waste gate aint goign any where lol
i hate snow, missing my celica
post Jun 26, 2009 - 12:37 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE (FunkySR @ Jun 15, 2009 - 6:28 PM) *
Yeah I got rid of mine too and got a breather thank. The small nipple is capped and the PCV hole goes to the breather tank, it catches oil and moisture and lets the air out... plus it's made by Stef's Fabrication so it's got my name on it biggrin.gif
QUOTE (malpaso @ Jun 26, 2009 - 9:56 AM) *
Thanks Martin!
Here's some finished pictures...
post Jun 26, 2009 - 2:38 PM
i dig the new wg a lot.
so hows it run now?
post Jun 26, 2009 - 6:01 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
It runs awesome now, better and smoother than ever. I just need to get to the dyno and do some more fine tuning. It's not easy to tune by myself while I'm trying to drive and pay attention to traffic at the same time.
post Jun 27, 2009 - 11:06 AM
97lestyousay
Joined Jul 7, '03
JDM guy made me do it.
post Jun 27, 2009 - 5:05 PM
FunkySR
Joined Apr 22, '07
Well done Steff. Awesome.
Lo-Fi Version Time is now: April 13th, 2025 - 9:02 PM
