5 Pages V   1 2 3 > »
> Fabricating Front Strut Bar
post Sep 30, 2007 - 10:50 AM
Qucifer
Joined Mar 20, '07
From www.manvsmetal.com
Everyone,
I will be fabricating a front strut bar for my Celica GT coupe, and am looking to see if there is any interest in them here. If so, I will make a JIG, and pump some out. Here are couple of pictures of a production run we made for the Nissan S-13 240sx. These are specifically designed for 240's with a top mount turbo setup, tall intake manifolds, or an RB engine swap. They are made with 1" steel tubing with a .095 wall thickness, and are powder coated with a wrinkle black finish. The celica bar will be made with the same type of materials, but it will have a design similar to the TRD strut bar. Let me know if there is any interest.
Q
post Sep 30, 2007 - 11:07 AM
torhne
Joined Jul 25, '07
From Montana
i would probably take one off your hands if they come out decent. how much are you thinking they will cost us?
post Sep 30, 2007 - 11:25 AM
Qucifer
Joined Mar 20, '07
We charged $150 plus shipping for the 240sx bars, and sold out of our first batch of 10 in 2 weeks. I am working on another batch of 15. On those each bar requires 4 bends which equals more time per peice. Its looking like the celica bar might have a total of 2 bends, so maybe $120 plus shipping. In the end it depends on the fab time per peice, could be more, could be less.
This post has been edited by Qucifer: Sep 30, 2007 - 11:26 AM
post Sep 30, 2007 - 12:00 PM
purepunishment
Joined Mar 20, '07
From Bradenton,FL
like to see one installed
post Sep 30, 2007 - 12:24 PM
Qucifer
Joined Mar 20, '07
When I get the prototype done, I will take pictures of it installed.
post Sep 30, 2007 - 1:48 PM
94st_santos
Joined Oct 3, '05
From Houston, Texas
I would probably take one from you, these are going to be 3-pt strut bars right?
post Sep 30, 2007 - 4:10 PM
Qucifer
Joined Mar 20, '07
Yes they are going to be 3 point, and way stronger than the flimsy stock GT bar. I took the stock one off today to take some measurments, and it literally flops around. I am fabricating mine to tie into the stock location on the firewall, and it will have a full ring on each tower, and a bar welded straight across tying the two towers directly together. A big improvement over stock.
post Sep 30, 2007 - 4:14 PM
j0e_p3t
Joined Dec 8, '05
From torrance/carson, ca
interested.
post Sep 30, 2007 - 5:36 PM
Qucifer
Joined Mar 20, '07
Thanks for the replies. I am actively working a prototype right now. I will try and post pics of the progess. Nothing wrong with showing you guys what goes into making one of these things. If anyone else is interested, please respond.
post Sep 30, 2007 - 7:58 PM
xs94st
Joined Aug 11, '07
From Corona, CA
sounds great, can't wait to see it
Pandelica 2.0 in progress.
post Sep 30, 2007 - 8:26 PM
Qucifer
Joined Mar 20, '07
Like I said, I am keeping a photo log of the prototyping process. Here are a couple of pics. The first is the strut ring. It is oblong for maximum surface area to weld the cross bar to. I designed it today on my cnc plasma cutter. It is the same for both sides. Next is a couple of pics with the tube mitered to the proper angle. It is hard to tell, but there is a very steep angle cut on both side of the tube. The tube will be welded where it sits , and I will weld caps to the open ends of the tube. I will design the firewall bracket, and tubes this week.
And Yes that is duct tape on my air box tube.
post Sep 30, 2007 - 10:52 PM
94st_santos
Joined Oct 3, '05
From Houston, Texas
yea 3-pt with the bar across is definitley what i had in mind, im interested...
post Sep 30, 2007 - 11:52 PM
brthrurik
Joined Mar 24, '06
From Aloha, Oregon
definitely interested...
post Oct 1, 2007 - 7:42 AM
jcbass7
Joined Apr 20, '06
From Florida
are you going to fab these so they clear a 3sgte motor as well? if so that would open up the market a bit more
post Oct 1, 2007 - 8:13 AM
Qucifer
Joined Mar 20, '07
jcbass7, I would need to have contact with someone who has a 3sgte swapped Celica to build one off of. Im located in Oklahoma City, so if there is a 3sgte celica owner near by, hit me up.
On another note, when the prototype is finished and I have the jig made, I will need non-biased test person to take the first production piece and do a write up on the level of difficulty to install, the overall look of the peice, and the degree of functionality. This will help iron out any bugs before I make a full production run. I will offer more details when the peice nears completion.
post Oct 1, 2007 - 7:41 PM
Qucifer
Joined Mar 20, '07
Just throwig this out there. Would anyone who is budget minded be interested in just the 2 point cross bar? I would be willing to let them go for $50 unpainted plus shipping.
Here is why I ask. Since I have been desgining the 3 point bar over the past couple of days, I have been driving around without any bar on the car. I welded the straight bar to the mounts today, and decided to take the car for a quick run around the block. Funny to say that one bar makes a huge difference in stiffness and steering response, so I know that its functional. I will still be making the 3 point bar, but the option for both is out there.
Thanks
Q
post Oct 1, 2007 - 8:17 PM
xs94st
Joined Aug 11, '07
From Corona, CA
id be interested. want to see how it looks though. the bars that ive seen in 350z's that have two parallel bars that are welded together and havea huge base are what i would like.
post Oct 1, 2007 - 8:54 PM
zero07
Joined Apr 15, '07
From san antonio tx.
Also interested
post Oct 1, 2007 - 10:45 PM
cjh4l22
Joined Oct 18, '06
From cincinnati
interested in either/or. 3pt, single bar, or would it be possible to do a double bar type design? w/e interested all the same.
post Oct 2, 2007 - 6:04 AM
Qucifer
Joined Mar 20, '07
A twin cross bar design might be possible. I will check the fitup today, and let you all know. Also, I am building my bars off of the GT, and I do now know if it will fit the ST. Can somebody let me know.
5 Pages V   1 2 3 > »
Lo-Fi Version Time is now: February 22nd, 2025 - 12:42 AM
