4 Pages V  < 1 2 3 4 >
> Gettin my header today :D
post Oct 6, 2007 - 8:56 PM
punkuup5150
Joined Apr 10, '07
From lodi, ca
is the increase in power and soudn worth the trouble of doing this? i mean my cast iron exahust manifold is cracked im guessing from server hea to cold which i dont understand sincei live in the valley here in cali i bought the celli that way but im not sure if its worth all the work to do this so i can have a set of headers on my 97 st a lil xtra power would be awsome but the hassel im not sure if its worth it and this is coming from the guy whos goign to be doing all his own bodywork and paint the car once i get the paint in stupid special colors take forever to have come in. esp if your getting a backdoor hook up outta a paint store hehehe. but still what should i look forward to paying for a fully finished header for the celi after all the xtra o2 ports r put on and the pipeing and such is done? just a rough estimate woudl be awsome thx
post Oct 6, 2007 - 9:36 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
sounds much like mine, click my sig to hear it. i JUST have the stock cat, resonator, and stock pipe to the back.
post Oct 10, 2007 - 7:06 PM
CAMAricer
Joined Jul 25, '07
From San Francisco
Hey guys. I also got myself one of those Ebay headers. But I got one for my 97 ST. So I see that these headers are about 3 inches too short...
Anyways, so I was looking around for a resonator pipe on Ebay (to deal with the noise afterwards) and saw two different listings...one for a 94-95 ST and one for a 96-97 ST (price was different too, by like $20, same seller).
So now I'm thinking if there's a difference between these years (in terms of their exhaust system).
So here's the question. Are there differences between the exhaust systems of the 94-95 and the 96-97? Because that seems to be the case.
I haven't actually taken out my exhaust header yet to see if my Ebay one fits, but in the mean time if any of you guys know the answer to this, it'll save some of us with 96-97s some hassle and time.
2002 SC430 (WC) - 19" SSR Comp-H, Daizen swaybars, Sparco Demons, JDM Soarer conversion, carbon fiber spoiler, Injen intake, front strut bar, drilled/slotted Brembo rotors
1997 Celica ST (DD) - 17" ADR, ViS Zyclone CF hood, ViS CF hatch, K&N intake, Invader body kit
post Oct 10, 2007 - 9:37 PM
Bitter
Joined Mar 11, '06
type of O2 sensor hookup, earlier models have a flange, latter are screw in.
post Oct 11, 2007 - 3:09 PM
Komail
Joined Jul 29, '07
I have the 97 ST, can i change the 02 sensor hookup from a screw to the flange? what do I need and where do I get it?
post Oct 11, 2007 - 3:18 PM
mobsterk
Joined Oct 4, '07
From San Diego
u can change it, as long as the muffler shop is willin to do some adaptations to the pipes etc
post Oct 11, 2007 - 3:47 PM
Komail
Joined Jul 29, '07
No, I mean convert the upper o2 sensor from a screw to flange....how would you do that...
post Oct 11, 2007 - 9:15 PM
Bitter
Joined Mar 11, '06
why not just return it and buy the right one?
post Oct 11, 2007 - 11:09 PM
Komail
Joined Jul 29, '07
QUOTE(Bitter @ Oct 11, 2007 - 9:15 PM) [snapback]604144[/snapback]
I got the header from ebay for 65 shipped...if I return it and buy the right one, thats like going to be more money frown.gif and time LOL better to convert lol..
post Oct 12, 2007 - 12:50 AM
xs94st
Joined Aug 11, '07
From Corona, CA
ey komail u want it to be a screw in not a flange? u can have a muffler shop weld on a a flat piece over the existing flange on the downpipe n then get a hexnut the appropriate size, drill a hole in the flat piece, then weld that hexnut ontop. then, just screw in the o2 sensor.
also, is to every1 in general, is it bad that my CEL has not yet gone on despite the fact i dont have a 2nd o2 sensor in at all? i just unplugged it from the harness..
Pandelica 2.0 in progress.
post Oct 12, 2007 - 10:44 AM
Komail
Joined Jul 29, '07
I think its called an O2 bung, i can have that welded in to make it work out...
post Oct 13, 2007 - 1:38 AM
Komail
Joined Jul 29, '07
O
This post has been edited by Komail: Feb 10, 2010 - 12:31 AM
post Oct 13, 2007 - 2:02 AM
xs94st
Joined Aug 11, '07
From Corona, CA
What were you guys saying when you have to BORE out holes in the header to make it fit? I was kinda confused on that part...thanks for the feedback, I have pics to take...lol
yea, when i tried to put my header on (directly onto the head bolts) it would not line up all the way. i had to bore it out a lil bit in each one so that the bolts would all get through. it was still a snug fit, i just used the nuts for the header to tighten it onto the head.
My second minor issue is that I have a slight rub/vibration from the midpipe touching the crossmember part of the frame, I think I will bend something and make it fit a little later.
theres the original support that held the downpipe in place (made of rubber, held in a couple of bolts) just get rid of the rubber and weld a small bar there (on the metal part of the rubber support) and onto the downpipe. should be snug.
Since I have a screw in type and the header is for a flange type. How can I make this work? my friend suggested to cover the flange hole and drill a new hole with a o2 sensor bung. Where can you buy a cover for the flange?
just have the muffler shop (or whatever shop) find a scrap piece from somewhere that is rather thick and able to weld on. have them weld it into place n then drill the hole so that u can place the o2 sensor inside.
post Oct 13, 2007 - 2:06 AM
FortuneCookie
Joined Dec 12, '06
From Fob Sharana, Afghanistan
About the 2 types of O2 sensors. I'm pretty sure that you can buy an open flange type sensor from autozone that should plug and play into your header flange.
post Oct 14, 2007 - 9:16 PM
Komail
Joined Jul 29, '07
gonee
This post has been edited by Komail: Sep 29, 2015 - 11:50 PM
post Oct 16, 2007 - 9:56 AM
Komail
Joined Jul 29, '07
bump...
post Oct 22, 2007 - 8:48 PM
Komail
Joined Jul 29, '07
gone
This post has been edited by Komail: Sep 29, 2015 - 11:49 PM
post Oct 22, 2007 - 9:04 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
i remember using copper hi temp sillicone in between the header and downpipe to seal it better than that gasket
post Oct 22, 2007 - 9:12 PM
Bitter
Joined Mar 11, '06
the gasket that came with mine was just fine and i've had it apart and back together a couple times. just have to snug it down good so it seals well.
post Nov 3, 2007 - 4:01 PM
xs94st
Joined Aug 11, '07
From Corona, CA
okay.
since installing the header, i've been hearing this sorta ringing sound.
at first, i thought it must be some loose nuts/bolts in the downpipe.
tightened them, started driving n the sound is mainly when im accelerating from 20-40mph.
i then thought it was hitting my crossmember (maybe crappy install by myself or the muffler shop didnt weld the downpipe support well enough)
took it back to the shop and there is a decent amount of clearance between the downpipe n crossmember. (around a centimeter) and unless my motor mounts are complete crap, it shouldnt be hitting there.
then i thought about the rusty bolts that i loosened on the cat. i tightened em n added some hi temp adhesive to 'em.
when gettin out from under the car, i saw the DP support that is welded on the new DP. it is fairly long, about 1-2 inches and an inch and a half wide with 2 holes in it. i was wondering, would that be causing the ringing? considering that there is alot of force on the DP there, would it vibrate that piece enough to create resonance?
im gonna remove it but i duno when because its a tite fit and i dont have any portable cutting tools besides a craphacksaw.
any suggestions, ideas?
thanks guys!
-xavier
Lo-Fi Version Time is now: February 17th, 2025 - 2:06 AM
