> AC and Radiator cooling fans
post Oct 4, 2007 - 9:11 AM
torhne
Joined Jul 25, '07
From Montana
is there a way to wire up aftermarket fans? i have seen different sized ones, but i dont know if they would plug right into where the stock fans go, or how i would go about doing that. so does anyone use aftermarket fans by any chance?
post Oct 4, 2007 - 9:53 AM
frosty
Joined Sep 1, '04
From Alabama
Why do you need aftermarket fans? I thought our fans were slim enough as is?
CLOSED on 25 acres!
-shop coming soon....
post Oct 4, 2007 - 10:08 AM
torhne
Joined Jul 25, '07
From Montana
mine were smashed when i bought the car, so im looking to replace them
post Oct 4, 2007 - 10:43 AM
frosty
Joined Sep 1, '04
From Alabama
Well, that explians it.
I don't have aftermarket fans (nor do I know anyone that does right off) but it shouldn't hard to install, not much to their wiring.
Also, this question should probably be moved to the Interior/Audio/Electrical/Wiring section (mabey the engine section since it's about cooling the engine)
CLOSED on 25 acres!
post Oct 4, 2007 - 4:30 PM
torhne
Joined Jul 25, '07
From Montana
ah ok, well i was looking at these fans and its gonna be close to $400 to replace both of them, i think thats just outrageous for 2 fans + motors. And i also dont have the original ones so i cant even messure them to get an idea of what size aftermarket ones i need frown.gif can anyone help me out?
http://www.eraceparts.com/item.jhtml;$...mp;PRID=1503602 that is kind of what i was looking at, fairly cheap look to be alright for the job, and i can have brackets made up to hold them in place
This post has been edited by torhne: Oct 4, 2007 - 5:04 PM
post Oct 4, 2007 - 5:55 PM
torhne
Joined Jul 25, '07
From Montana
i cant believe no one is using aftermarket fans. is there anyone with at least a rough guess? if not, im gonna order the 14 inch ones and hope for the best i suppose
post Oct 4, 2007 - 7:20 PM
lubu
Joined Apr 2, '07
From Great Western Plateau
i might have a pair..pmed.
98% completion
aaRon
post Oct 4, 2007 - 7:32 PM
xs94st
Joined Aug 11, '07
From Corona, CA
no celis in the junkyards?
Pandelica 2.0 in progress.
post Oct 4, 2007 - 7:57 PM
torhne
Joined Jul 25, '07
From Montana
nope. nearest junk yard is spokane i think, and last time i checked they only had 1 celi in it and it was picked clean. thats where i got my new front end from. it didnt even have lights or anything like that in it. but anyways, do you guys think 14 inch universal would be small enough to fit in there if i had some sort of brackets made for it?
post Oct 4, 2007 - 10:28 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Usually junkyards pull the fans along with the engines, so may well have them stored elsewhere. Try car-part.com
Lo-Fi Version Time is now: December 4th, 2024 - 6:07 AM
