Strange engine problem, need some help |
Oct 5, 2007 - 11:26 AM |
Enthusiast Joined Jun 2, '07 From Netherlands Currently Offline Reputation: 0 (0%) |
Since a month or so I have some problems with my engine. I have a AT200, with a 7AFE from 1994.
This is very hard for me to explain it in English but I'll try my best. Sometimes it seems like my engine doesnt get any fuel for a second and then it runs normal. It just suddenly drops in RPM and less then a second later it runs normal. It's kinda like a shock. And when it begins it doesnt stop shocking. Until I stand still. When my RPM is around 1000 and it drops, then the motor stops. When I start again, it runs normal again. This problem isnt always there. The car was at the garage and it run perfect for about a week. Then it begun again. Then when the mechanics at the garage drive in the car it runs normal. They are now searching and searching, but no succes. The problem is that the problem isnt always there. You can drive 150 km without troubles. And later you start it and after 5 km it starts shocking. Does anyone have a clue about what could be wrong? Thanks -------------------- |
Oct 5, 2007 - 11:36 AM |
i had the same issue twice with my old 5th gen. the first time it was a bad spark plug wire intermittently losing connection.. another time it was my ignitor and i'd lose power.
Oct 5, 2007 - 12:07 PM |
spark plug wires are replaced.
Does a failing ignitor also explains that it mostly runs perfect and then suddenly doesnt? -------------------- |
Oct 5, 2007 - 12:14 PM |
Sounds like it might be the ignitor, but you might want to check all of your fuses and relays
Oct 5, 2007 - 2:41 PM |
Enthusiast Joined May 7, '04 From Leeuwarden, Netherlands Currently Offline Reputation: 0 (0%) |
Could be ignition, clogged fuelfilter, rotten airsensor, crappy servo. Succes with it.
This post has been edited by Silvan: Oct 5, 2007 - 2:46 PM |
Oct 5, 2007 - 2:47 PM |
well, it does it too often too not worry about it. The mechanics at the garage have already looked at the ''normal'' things, like ignition and fuel filter.
It must be something else. -------------------- |
Oct 5, 2007 - 2:51 PM |
It's most likely something electrical.
Bad connection somewhere probably. This kind of stuff is a real PITA to find... -------------------- |
Oct 5, 2007 - 4:15 PM |
Well I had the same kind of problem, except mine didn't go on for a long time.. it happened a few times and then I finally lost spark, but it was a bad relay.
Lo-Fi Version | Time is now: November 29th, 2024 - 6:24 PM |
