Enthusiast Joined Sep 25, '07 From North Charleston South Carolina Currently Offline Reputation: 0 (0%) ![]() |
Will jdm hatchback tails fit on a 94 st coupe... need some help
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 4, '07 From US Currently Offline Reputation: 2 (100%) ![]() |
no they will not, they are entire different shape
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 15, '05 From Toronto Currently Offline Reputation: 4 (100%) ![]() |
what you can do if you want some JDM goodies for your coupe, there is car in Japan called a curren. Its based off the AT200 platform, aka the celica coupe platform. It has basicly the same tails as a USDM coupe for the 94-96 years, but the 97+ have a bit different tail light.
Example Im using Coomer car OEM USDM Coupe/Convertable tails ![]() and Coomer's car with Currens ![]() They are the same shape, but have a bigger clear section and they have a light tint on the lens. Much better looking IMO. They run about $210 give or take. |
QUOTE(Valo666 @ Oct 6, 2007 - 11:50 AM) [snapback]602397[/snapback] what you can do if you want some JDM goodies for your coupe, there is car in Japan called a curren. Its based off the AT200 platform, aka the celica coupe platform. It has basicly the same tails as a USDM coupe for the 94-96 years, but the 97+ have a bit different tail light. Example Im using Coomer car OEM USDM Coupe/Convertable tails ![]() and Coomer's car with Currens ![]() They are the same shape, but have a bigger clear section and they have a light tint on the lens. Much better looking IMO. They run about $210 give or take. ![]() -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) ![]() |
http://www.echodrivers.com/forums/viewtopic.php?t=12084
im in the process or playing around with similar ideas, when i get the balls, gonna try n make some sick led tails outta the currens i have and yes, for all those at the earlier csp, you WILL know when im on the brakes. im workin on following that for an 00 echo sedan, and ive played around a lil bit with my lil rc car, but i want the celica to look as sweet as it does from the front as it does from the rear, an di think some leds will do the trick, gonna try an infinity look edit: i think the yelli celi needs to teach its new owner some photography skills ![]() This post has been edited by jason: Oct 7, 2007 - 2:35 PM -------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
![]() ![]() ![]() ![]() (2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
if you get it to work Jason, if i sent you a set of coupe tails and a set of FX45 tails with the LEDs already there, would you be willing to make me a set for sarahs car?
QUOTE edit: i think the yelli celi needs to teach its new owner some photography skills Well when the owner gets a better camera maybe. For now I'm rocking a crappy 3MP camera. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
haha sorry to knock on your camera =(
but yes, if all goes well i plan to at least put up a how to, and those willing to part with their tails for some time i could even do it for ya. i plan to do similar to how he did in that thread of actually making the leds in whatever pattern/design you wish, for the turns, i plan something similar cept a more < > clearing pattern going only from inner to outer. but imo, i think people should try n go the extra mile with what you have instead of makin hatch tails on a coupe, make something that noone else can easily copy AND make your car stand out in the process with advanced oem styling, instead of the mid 90's styling it has now. if that makes sense -------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
Lo-Fi Version | Time is now: February 22nd, 2025 - 12:22 AM |
