![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 15, '07 From Fort Worth, TX Currently Offline Reputation: 12 (100%) ![]() |
I have some JBL tweeters and I was wondering if I could replace the factory ones with these. Here are some pictures of how big they are and the plug they use, could these by plug and play?
![]() ![]() ![]() -Matt This post has been edited by GotToyota: Oct 8, 2007 - 5:18 PM |
![]() Enthusiast ![]() ![]() ![]() Joined Jun 8, '07 From Houston, Texas Currently Offline Reputation: 1 (100%) ![]() |
let me know if it works cause i need new ones... i cant play high range stuff cause they crackle
Enthusiast ![]() Joined Aug 19, '07 From new providence P.A. Currently Offline Reputation: 2 (100%) ![]() |
you shud be able to just remove the old tweeters and cut the wires and wire the new ones right up with out a broblem as long as the tweeters you got have the corect whole in the back to mount to the bracket.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 15, '05 From Toronto Currently Offline Reputation: 4 (100%) ![]() |
thouse dont look like they will work. The ones i replaced mine with look like this.
![]() ![]() you need to get a tweater thats 1" or smaller and it needs to be abel to mount in the rear by a single bolt. Also, when replacing the tweaters, your gonna need to dremil out part of the tweater cover to allow for the bigger speaker grill. |
Lo-Fi Version | Time is now: February 22nd, 2025 - 6:44 AM |
