> Engine Temp Sensor Location
post Oct 8, 2007 - 8:14 PM
DangerboyJr
Joined Sep 30, '07
From Ontario
So, My engine temp guage keeps shutting off... Where is the sensor located so I can check it
post Oct 9, 2007 - 3:37 PM
DangerboyJr
Joined Sep 30, '07
From Ontario
Nobody?
post Oct 9, 2007 - 8:12 PM
alltracman78
Joined Aug 9, '06
From Ma
It should be on your coolant elbow where all the sensors are.
It has a light blue wire with yellow stripe.
Only 1 wire to the sensor apparently.
There is also a ground that interestingly enough is on the rear of your intake manifold.
It will be a 10mm bolt holding it.
That ground is for a whole bunch of things, so I doubt that is the problem.
post Oct 10, 2007 - 3:06 PM
DangerboyJr
Joined Sep 30, '07
From Ontario
Thanks ATM
Lo-Fi Version Time is now: February 22nd, 2025 - 5:40 AM
