> custom CF pieces..
post Oct 12, 2007 - 12:22 AM
xs94st
Joined Aug 11, '07
From Corona, CA
say i wanted to create some accent pieces, not necessarily performance cuz with an ST theres not much left to perform..say front n rear CF diffusers n side accents..JUST for show..
how would i do it?
i know that you gotta get a rough shape of what its gonna look like, then cut/sand it to make it match perfectly, then u gotta get maybe kevlar n CF to wrap it with along with the adhesives to make it all stick together. also gotta vacuum fit the CF to the piece, so u could possibly get a high velocity vacuum n tape some sort of plastic around it so that it can form fit itself n get a snug fit. leave it vacummed overnite to cure n then remove the plastic n voila?
this is my noob idea of the steps in making these pieces.
can any1 please correct me in all places necessary?
i want to do this on my own, whn i have the time, doing one piece at a time.
thanks for lookin out!
x
Pandelica 2.0 in progress.
post Oct 12, 2007 - 9:15 AM
ra65_22re
Joined Aug 21, '06
From washington
There is a How-To on this.
post Oct 12, 2007 - 9:21 AM
if you wanted a CF rear diffuser go to VARIS...its the BEST way to do it
something of this magnitude isn't for the 1st time CF user
CF is very expensive to make/use and isn't an easy material to work with.
vacuum bagging is also a detailed process with several different components
here is something i made for the coupe
and a BMW piece
next in my line up of products is going to be Doors and sunroof plug smile.gif
post Oct 12, 2007 - 9:34 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
Dan thats mint!
post Oct 12, 2007 - 9:49 AM
thats the only one i could find atm of it installed on the customer's car
post Oct 12, 2007 - 9:50 AM
jcbass7
Joined Apr 20, '06
From Florida
dan is that trunk lid wrapped or a full cf replacement? whats it weigh?
post Oct 12, 2007 - 9:53 AM
show purpose only so it was a wrap job.
when i make my doors this winter, they will be a fiberglass door (not sure if i'll lay any CF on it) which will save a good amount of weight.
the sunroof will be a honeycomb core material (ltw) and a Carbon skin...stock sunroof weight ~25lbs i think.
i'll have weights and stuff later when the project is actually started
This post has been edited by playr158: Oct 12, 2007 - 9:56 AM
post Oct 12, 2007 - 1:45 PM
xs94st
Joined Aug 11, '07
From Corona, CA
alritey. thanks for the feedback guys! i appreciate it. when i have some more money, imma invest in some CF so that i can tinker n wrap my own stuff then continue to learn about it all.
thanks all!
post Oct 12, 2007 - 4:03 PM
Valo666
Joined May 15, '05
From Toronto
how much would it cost to wrap a trunk in CF dan?? That looks hot.
post Oct 14, 2007 - 1:34 AM
wrapping a trunk is about $400
This post has been edited by playr158: Oct 14, 2007 - 1:34 AM
Lo-Fi Version Time is now: November 30th, 2024 - 10:53 AM
