> Everyone's on the 5SFTE band wagon, I'm doing it too
post Oct 12, 2007 - 8:38 AM
Element
Joined Apr 16, '04
From Raleigh, NC
After reading posts in the forum and browsing around websites for a while I’ve decided to start building my 5SFTE kit…I wanted to list out everything I’m planning on for recommendations from you guys. My goal is initially ~200whp but I’d like to eventually reach 250whp (I’m gonna agree with jgreening here and say the vert won’t like much more…)
3SGTE Oil pan
Custom FMIC from 97Celica
315cc 7MGE injectors
Turbo – T3/T04B V trim, water-cooled from blaastperformance.com
Exhaust manifold/downpipe – Product #aaaa10218 from ssautochrome.com
Walbro 255 lph high pressure fuel pump
Greddy Emanage Ultimate (not sure this is my best option but seems most versatile…)
3SGTE 2bar MAP Sensor (anyone have one?)
Boost controller (probably manual, but electronic if I can find a deal)
Greddy universal BOV (haven’t decided on a model…what should I look for?)
Magnaflow race muffler and high-flow cat
A-pillar gauge pod w/ boost, oil pressure and EGT
I’m currently living away from home but I’m planning to start the build when I move back home in December. I’ve got plenty of time to shop around for bargains and such so hopefully I can do everything for $2500 or so…low I know, but I’m gonna try! Let me know what you guys think.
post Oct 12, 2007 - 10:34 AM
99GT
Joined Dec 14, '06
From MN, USA
New Injectors!
post Oct 12, 2007 - 12:07 PM
1bwilson
Joined Aug 30, '02
From Maryland
You want the 460 rx7 injectors and Id recomend sending them to witchhunter.com for a cleaning. The 315's are from the old school settup and Manny proved them to be to small.
Member of Team 5sfTe
post Oct 12, 2007 - 2:04 PM
Element
Joined Apr 16, '04
From Raleigh, NC
they were cheap so I jumped on it, figured if I needed bigger I could sell them pretty easily
post Oct 12, 2007 - 4:50 PM
ditch the SSautocrap manifold. its 100% junk. it WILL crack.
the downpipes are ok at best, some last (as long as you use the support bracket) some dont.
use a stock alltrac or mr2 exhaust manifold.
bryan covered the injectors.
interesting turbo selection, what made you pick that particular turbo?
post Oct 15, 2007 - 3:13 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
mine hasn't cracked yet.
post Oct 15, 2007 - 3:47 PM
QUOTE(rjbibeau @ Oct 15, 2007 - 4:13 PM) [snapback]605101[/snapback]
YET.
it will, they all do.
shannon swore hers wasnt either...till i pulled teh turbo and showed her the nice big crack starting on the underside, at the weld.
post Oct 15, 2007 - 7:08 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
i'll just have it rewelded when it cracks and have the rest of the welds reinforced
post Oct 15, 2007 - 7:28 PM
the welds aren't the only problem. its super thin stainless, trying to hold up a heavy ass turbo, that has no other means of support. its going to crack. period.
post Oct 15, 2007 - 7:55 PM
6strngs
Joined May 12, '06
From Wilmington, NC
there may be an oil kit available shortly that would eliminate the need for a 3sgte oil pan and other things and will simplify the process alot.
post Oct 15, 2007 - 8:09 PM
QUOTE(6strngs @ Oct 15, 2007 - 8:55 PM) [snapback]605191[/snapback]
since hes not using a ct-26, i fail to see how your "oil kit" will simplify anything.
post Oct 16, 2007 - 1:36 PM
Element
Joined Apr 16, '04
From Raleigh, NC
That turbo pick wasn't very well educated...it's not going to suit my needs, the T04 compressor wheel is too large...but I'm looking more at pricing right now than anything...
Are there any good sites with rebuilt CT-26's?
post Oct 16, 2007 - 2:44 PM
CaliJeff
Joined Apr 22, '07
From Bay Area, California
atsracing.net
You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=-
post Oct 18, 2007 - 10:19 AM
Element
Joined Apr 16, '04
From Raleigh, NC
so i'm coming to the conclusion i might want to make some mods to prepare for a turbo setup...funds are tight ya know wink.gif
in december i'm going to do a thorough inspection/repair...i know i have to replace the rear main seal, rebuild/replace brake calipers, probably do axle seals while i'm at it...
what kind of mods should i do that would be good for a turbo setup? everyone says new clutch, reckon i'd do a lightweight flywheel at the sametime, should i do different brakes? any other mods i could do before the turbo? suspension/handling might be nice...
and any recommended clutch kits, brake kits, suspension kits? been reading through and learning a lot in general, just trying to decide when to do what...
post Oct 18, 2007 - 3:01 PM
6strngs
Joined May 12, '06
From Wilmington, NC
you could do a metal head gasket and head studs. but it's not really necessary. just make sure you have a good aftermarket clutch. Brakes and suspension aren't needed, but they sure don't hurt. Unless you have tons of money though, the most you can do for your brakes is some high performance pads, stainless lines, and maybe cross drilled and slotted rotors if you're into that kind of thing.
post Jan 7, 2008 - 6:46 PM
Element
Joined Apr 16, '04
From Raleigh, NC
slowly working my way toward putting the t in 5sfte!
virtually rebuilt the engine (everything but new crank and pistons...journals are all ok and compression is great...) and i got my spec stage 2 clutch tonight!
lots of pics will be coming once it's all together...either tomorrow late or next weekend since i start back to classes wednesday
post Jan 8, 2008 - 12:03 PM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(Element @ Oct 12, 2007 - 7:38 AM) [snapback]604295[/snapback]
My opinion on this has changed over time. I was running about 270whp before I sold my car with no noticable ill-effects due to chassis ridgity. Nevertheless, that doesn't address the traction issue. I still believe that going for much over 250whp in our cars has limited value due to poor traction (and torque steer w/o a LSD) from the FF configuration.
Lo-Fi Version Time is now: January 11th, 2025 - 9:44 PM
