7afe turbo kits |
7afe turbo kits |
Oct 12, 2007 - 2:18 PM |
Enthusiast Joined Oct 5, '07 From minneapolis,mn Currently Offline Reputation: 0 (0%) |
to all of my fellow 7afe owners i was doing research on turbo kits and i came across a web site that makes turbo kits for 7afe its not for celica its for a corolla motor, corolla and celica 7afe motors are the same if you are interested here is the web site
http://streetlevelperformance.com/Toyota_T...rbo%20Kits.aspx This post has been edited by xiongst: Oct 12, 2007 - 2:28 PM |
Oct 13, 2007 - 5:42 AM |
Enthusiast Joined Nov 27, '02 From Derry,NH USA Currently Offline Reputation: 9 (100%) |
I have a 7afe turbo header for sale! PM me!
Oct 16, 2007 - 10:34 AM |
Enthusiast Joined Sep 26, '07 From iowa Currently Offline Reputation: 1 (100%) |
do i need to up grade my fuel pump and injectors if i run a turbo? what all needs to be done to the motor ect. to get it ready for a turbo?
-------------------- -Boss III
Oct 18, 2007 - 6:39 AM |
Enthusiast Joined Nov 16, '06 From Findlay,Oh Currently Offline Reputation: -1 (33%) |
QUOTE(addictions @ Oct 16, 2007 - 3:34 PM) [snapback]605418[/snapback] do i need to up grade my fuel pump and injectors if i run a turbo? what all needs to be done to the motor ect. to get it ready for a turbo? ull have to get an upgraded fuel pump and injectors u can just use 1st gen turbo probe injectors which are like 300 cc or around there...ull need oil restrictors for the turbo it self cause it will smoke really bad if u dont and use half inch return line for the turbo as well.advance ur timming to 16,,,and use check valves for ur map sensor so it doesnt give the engine a knock due to the computer will retard the timming when under hard boost..u dont really need to do much if ur planning on runing under 8 psi... |
Lo-Fi Version | Time is now: December 4th, 2024 - 6:57 PM |
