Does my car have ABS???, How do you know if it does or doesnt? |
Oct 13, 2007 - 12:07 PM |
Enthusiast Joined Jun 5, '07 From Santa Maria Currently Offline Reputation: 1 (100%) |
Hey guys I was just wondering, how do you tell if the car has ABS or not? I don't have a light on the inside that says anything, like newer cars do, but how do I know?
I was wondering because I think I need to replace my driver side axle and while I was looking it said that some were for cars with ABS and others were for the cars without it. I have a 1996 GT hatchback. Any info would be great. Thanks guys!!! -------------------- |
Oct 13, 2007 - 12:33 PM |
Enthusiast Joined May 15, '05 From Toronto Currently Offline Reputation: 4 (100%) |
pop your hood, on the passanger side inner fender beside where you add washer fluid, you will see a metal block with like 10 different lines running into it...if you see that..its got ABS, if you dont, you dont..lol Also another way to check is drive, slam on the brakes, if you feel a pulsation in the pedal and the tires dont lock up..you have it...if your tires lock up completely, then you dont have it.
EDIT: since yours is a GT aswell, you most likely have ABS. I havent seen a GT without ABS. This post has been edited by Valo666: Oct 13, 2007 - 12:35 PM |
Oct 13, 2007 - 2:26 PM |
Enthusiast Joined Aug 11, '07 From Corona, CA Currently Offline Reputation: 4 (100%) |
thats where it supposd to be. its exactly as valo described it. -------------------- Pandelica 2.0 in progress. |
Oct 13, 2007 - 4:40 PM |
Enthusiast Joined Apr 22, '07 From Bay Area, California Currently Offline Reputation: 14 (100%) |
gt96 and up for sure have it
-------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=- |
Oct 13, 2007 - 7:06 PM |
Enthusiast Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) |
Ive got a 95 GT w/o
-------------------- Member of Team 5sfTe
Oct 14, 2007 - 12:34 AM |
Enthusiast Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) |
QUOTE(CaliJeff @ Oct 13, 2007 - 2:40 PM) [snapback]604648[/snapback] gt96 and up for sure have it I have a 96GT and I don't have ABS. -------------------- |
Oct 14, 2007 - 11:54 AM |
really? wow, nvm then !
Oct 14, 2007 - 12:10 PM |
Enthusiast Joined May 23, '06 Currently Offline Reputation: 0 (0%) |
I have a 97 st limited w/o abs
Oct 14, 2007 - 12:13 PM |
Thanks guys!!! I'll be sure to pop my hood and check it out.
Oct 23, 2007 - 6:18 PM |
Enthusiast Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
I got a 94 GT without it.
anyway, we just talked about this in class last night. the quickest and easiest way to tell is just to turn your key to the on position, and most of the lights on your dash will light up, like check engine light, airbag light, check oil light, etc. now, if you see an ABS light, then you have it, if you don't then you probably don't (I say probably don't because, the bulb could have just burnt out, or some other electrical problem could cause the light not to come on... but that's pretty unlikely) -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Oct 27, 2007 - 8:49 AM |
QUOTE(6strngs @ Oct 23, 2007 - 7:18 PM) [snapback]607767[/snapback] I got a 94 GT without it. anyway, we just talked about this in class last night. the quickest and easiest way to tell is just to turn your key to the on position, and most of the lights on your dash will light up, like check engine light, airbag light, check oil light, etc. now, if you see an ABS light, then you have it, if you don't then you probably don't (I say probably don't because, the bulb could have just burnt out, or some other electrical problem could cause the light not to come on... but that's pretty unlikely) the quickest, easiest, and most accurate way to tell would be to do as valo said. open your hood, and look for the abs actuator, located on the passanger side frame rail. (for USDM cars ) -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Oct 27, 2007 - 1:29 PM |
Enthusiast Joined Jul 7, '06 From Los Alamos, NM Currently Offline Reputation: 1 (100%) |
i have a 99 gt w/o abs...... damn i want it though
-------------------- 2015 Subaru WRX. World Rally Blue/Black
2001 Honda S2000. Spa Yellow/Black |
Nov 5, 2007 - 11:22 AM |
Enthusiast Joined Jun 13, '06 From Omaha, Nebraska Currently Offline Reputation: 11 (100%) |
My 97 GT doesn't have ABS. And, I think the easiest way to check would be to slam on the brakes on gravel and see if the pedal vibrates back at you.
-------------------- We shall show mercy, but we shall not ask for it. |
Nov 17, 2007 - 10:17 AM |
Enthusiast Joined Nov 14, '07 From Jersey, TR Currently Offline Reputation: 0 (0%) |
If you want you can just take apart the master cylinder and look for all those abs cylonoids in that big metal box looking thing. Looks like a bunch or batteries.
-------------------- One BAD ASS CAR!!!
Nov 18, 2007 - 12:02 AM |
QUOTE(SilentNight @ Nov 17, 2007 - 10:17 AM) [snapback]615046[/snapback] If you want you can just take apart the master cylinder and look for all those abs cylonoids in that big metal box looking thing. Looks like a bunch or batteries. wtf are you talking about ? take apart the master cylinder to see if you have ABS ? this is the ABS control unit in the bay. All of the brake lines go from the wheels, to the some splitters, then to that unit, and then to the master cylinder. Trust me, I know. -------------------- |
Nov 18, 2007 - 1:09 AM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
^ 4 lines out for the 4 tyres (independent/ABS) 2 lines out(front and rear?)
Nov 18, 2007 - 11:20 AM |
wait a sec......o nm....im thinkin of sumthing else i was thinking for su reason that the control unit was by the master cylinder. At the time i was reading an artical bout bench bleeding and i probly got my words mixed up. What i ment was, ware the abd control unit is, look inside the metal box thing and look for the cylinoids. Which look to me like a bunch of batteries.
Lo-Fi Version | Time is now: December 12th, 2024 - 1:43 PM |
