> Engine swap, Have the 3S-GE want the GTE
post Aug 11, 2003 - 10:03 PM
madlion586
Joined Aug 2, '03
From Barbados
Hey guys I've got a JDM with the 3S-GE and I want to go with the GTE from a '94-'98 GT-Four with 251hp. Does this make sense? and Where can I get Just the engine? cause I'll get screwed importing more than that here in Barbados. Duties will screw your budget. Help!!!! smile.gif
post Aug 14, 2003 - 1:31 PM
scothaniel
Joined May 1, '03
From Michigan
You have a 3rd gen 3SGE already?
With or without VVTI?
This post has been edited by scothaniel: Aug 14, 2003 - 1:32 PM
Scott
West Michigan
post Aug 14, 2003 - 2:36 PM
QUOTE (scothaniel @ Aug 14, 2003 - 10:31 AM)
He has the one without VVT-i. I'm not sure where you'd be able to find just the engine in Barbados though. I know of a bunch of places in the US, but I'd think that it'd cost a lot to get it over to Barbados.
post Aug 14, 2003 - 3:04 PM
scothaniel
Joined May 1, '03
From Michigan
If it is the 3rd gen non-VVTI, then there is little reason to get a ST205 engine. The 3rd gen 3SGE has a nearly identical block and head. I'm in the process of converting the same engine to turbo, and I've completely tore the engine apart.
The head has the same valves and port design as the ST205, with the only real difference being more aggressive cams since its NA. The manifold bolt pattern is identical to the ST205, so the exhaust manifold will bolt right up.
The block has the same rods, crank, water and oil passages as the 205 as well. The difference between it and the 205 block are high-compression pistons and the lack of oil lines to the turbo. The oil return port is there on the top half of the oil-pan, and just needs to be drilled out and have the elbow bolted on (which can be purchased from the local Toyota dealership). I think the ST185 elbow will work as well.
The pistons are the main difference for the block, being 10.5:1 versus 8.5:1. If you were to run low boost (like putting a turbo on the 5SFE) then the high compression pistons would be fine. It would probably be a good idea to through some higher flow injectors on it (the 3SGE has the same 250cc?? injectors as the 5SFE) - maybe from a DSM. The injectors are top fed, so the 3SGTE and Supra injectors wont work. Or you could get a fuel rail from the ST205 and use the stock 3SGTE injectors (440cc). To push more then low boost, you would need a fuel controller (maybe full EMS) and much bigger injectors to make up for the high compression. I;ve heard there is a turbo'd 3rd gen 3SGE in the states running the stock pistons and putting down a lot of power.
Another option is to swap out the pistons with low compression pistons from the 3SGTE motors. I am going this route, and using the stock ST185 pistons with new rings. You would definately need big injectors with this setup, along with a different ECU - I'm using the ECU from a 3rd gen MR2 since I'm not using the W/A IC. I'm trying to source a stock 205 fuel rail to use a set of Supra injectors, but if I cant find one for a good price I'll just buy a set of RC top-fed 550'c for the DSM's.
I fully believe this engine will produce as much power as a stock 205 at around half the cost of a 205 clip.
Scott
West Michigan
post Aug 14, 2003 - 4:06 PM
That sounds like a cool project Scothaniel! Thanks for all the detailed information too. smile.gif
post Aug 14, 2003 - 5:31 PM
madlion586
Joined Aug 2, '03
From Barbados
Thanks for all the great info Guys. This really is a good site for 6GC owners. I appreciate the help. My only problem has been in getting stuff at a good price in this screwed up place. I'll definitely think about what you suggested. smile.gif
This post has been edited by madlion586: Aug 14, 2003 - 5:32 PM
post Aug 14, 2003 - 5:43 PM
madlion586
Joined Aug 2, '03
From Barbados
Hey coomer can you get me Info on the places in the states? That might help.
post Aug 14, 2003 - 5:48 PM
I got my engine from a place called Storm Performance. They do sell just engines if you want. I'd suggest talking to Mark. He's a good guy and helped me out a lot with what I needed.
Also, there are some other places that I've heard good things about below.
Jarco <- Heard lots of good things about them
Toysport <- Heard good things about their products, mixed feelings about their service, and their prices are usually kinda high
post Aug 14, 2003 - 5:52 PM
madlion586
Joined Aug 2, '03
From Barbados
Having thought about it, The full engine swap might be easier and cheaper based on conditions here in beautiful Barbados(with high ass prices). The other way is a lot of work that I'm not qualified to do myself. These Jessie James mechanics here will rob me blind. The one Guy I trust can do the engine swap in two days. What do you all think.
post Aug 14, 2003 - 5:53 PM
madlion586
Joined Aug 2, '03
From Barbados
post Aug 15, 2003 - 9:26 AM
scothaniel
Joined May 1, '03
From Michigan
Thanks. I'd be able to post more info on this swap if I can just get time to drop the motor off at the machine shop. I've had the stipped down block in my basement for about a month now.
I'll second Jarco - best import place Ive dealt with, clean well organized shop and freindly people. Call them though, as they dont check e-mail as often enough.
I was going to order a 205 clip from ToySport, but they were way too expensive.
madlion586 - if you do swap the engine, I may know someone who would be willing to buy your stock motor off you. It wouldn't go for much compared to the cost of a 205 engine (I bought my 202 partial clip for $1200 and a 205 partial clip for $4300) but it would at least be something.
Scott
West Michigan
Lo-Fi Version Time is now: February 21st, 2025 - 5:25 PM
