> Hating 17s
post Oct 16, 2007 - 7:59 AM
phokur
Joined Aug 5, '06
From Maryland
So I went from 16" aftermarket wheels to 17" tc wheels. I will admit, they look awesome... but the ride quality sucks! I feel way more body roll, the vibrations through the steering has exponentially worsened, the back end will kick out which I couldn't do if I tried before, the car feels much much slower while accelerating, and I even think I dropped mpg! Anybody else experience this while transitioning? Any resolutions? kindasad.gif
post Oct 16, 2007 - 8:30 AM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
What size tires are on?
FlickR
post Oct 16, 2007 - 9:58 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
probably stock tire size..
17" wheels will weigh more (on average. There are some crazy light ones out there) which will effect your acceleration.
You probably feel more roll because now you're sitting up just a bit higher than before.
The resolution to it all.... lower your car. Lowering the car with tein's and koni shocks will dramatically reduce the body roll, as well as look great. You would also benefit from a rear sway bar from Suspension Tech, which would also negate some body roll and give the car better handling.
As for the wheels, you're going to have to live with it or sell them and put yout 16" wheels back on.
**** Photobucket
post Oct 16, 2007 - 10:21 AM
Sinyk
Joined Oct 4, '06
From Kelowna, BC Canada
I like my 17's and the ride quality is the same. It was poor when I first had them installed because they weren't balanced properly which caused a lot of steering vibration, but everything else is great.
post Oct 16, 2007 - 2:20 PM
phokur
Joined Aug 5, '06
From Maryland
My tires are 285-70-17. My old 16s are bent, so no going back. frown.gif But I guess I will be looking into lowering her. Was considering it anyway with how much it currently sags. I haven't balanced them yet, so that may be a good idea too. Thanks for the tips biggrin.gif
post Oct 16, 2007 - 2:22 PM
95CelicaST
Joined Feb 5, '05
285/70-17.... I hope you're joking.
Look again. That would be like... 10.5" wide tire.
If they are the stock tC tires then they are 215/45R-17
**** Photobucket
post Oct 16, 2007 - 2:24 PM
Sinyk
Joined Oct 4, '06
QUOTE(phokur @ Oct 16, 2007 - 2:20 PM) [snapback]605481[/snapback]
Yeah... there's your problem there. Balance them and your steering wheel vibrations will stop.
post Oct 16, 2007 - 2:45 PM
Gary
Joined Aug 28, '04
From FLA USA
QUOTE(phokur @ Oct 16, 2007 - 3:20 PM) [snapback]605481[/snapback]
I hope that's a typo.
Tires that size cannot be installed on a Celica.
_Gary
post Oct 16, 2007 - 4:11 PM
balance and alignment....
post Oct 16, 2007 - 4:27 PM
BLINKYxMUNKEY
Joined Nov 12, '03
285-70-17 is the perfect size for a truck. That's huge!
FlickR
post Oct 16, 2007 - 5:17 PM
phokur
Joined Aug 5, '06
From Maryland
Sorry, that's off of my old Jeep... 215/45ZR17. haha
post Oct 16, 2007 - 5:59 PM
BLINKYxMUNKEY
Joined Nov 12, '03
I have 215/45 on my wheels and they ride great. Alot better then the 215/40s I had. Take them to a tire store and have them check the balance and to look for any bent wheels. To get rid of the body roll, need to modify your suspension. Shocks, springs, sway bars, etc.
FlickR
post Oct 16, 2007 - 9:47 PM
jdg371
Joined Jun 14, '05
My 17x8 are only 16LB =]
post Oct 16, 2007 - 11:11 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
maybe the sidewalls aren't as stiff, and the overall quality of tires are different.
post Oct 17, 2007 - 1:32 AM
prowzee
Joined Jan 17, '07
From (CA) orange county
thats pretty big.. ive seen a integra with 60 series i guess they were trying to tuck tire or sumthing
post Oct 17, 2007 - 5:36 PM
j0e_p3t
Joined Dec 8, '05
From torrance/carson, ca
how's the tread life of the tires? bad tires could be the reason your rear kicks out on hard turns.
post Oct 17, 2007 - 5:55 PM
phokur
Joined Aug 5, '06
From Maryland
I'd say 80-90%, they're near new. I did hit the turn pretty hard, but I'm sure it would have stuck on my old 16s. Could just be the extra bodyroll putting additional stress on the outside tires. I think lowering should fix it. Don't think I'll go for the rear sway bar though, be getting too expensive.
post Oct 17, 2007 - 6:58 PM
95CelicaST
Joined Feb 5, '05
172.60 for rear sway.
http://www.nopionline.com/nopistore/dsp_pa...TOYOTA%20Celica
**** Photobucket
post Oct 17, 2007 - 10:33 PM
97Celica
Joined Nov 27, '02
From Derry,NH USA
people have no idea how much balancing does. it can really affect A LOT.
post Oct 18, 2007 - 8:56 AM
BLINKYxMUNKEY
Joined Nov 12, '03
QUOTE(97Celica @ Oct 17, 2007 - 11:33 PM) [snapback]605997[/snapback]
+1. I worked at Discount for over 2 years. Balancing helps the tire from wearing out funny and giving problems.
This post has been edited by BLINKYxMUNKEY: Oct 18, 2007 - 8:57 AM
FlickR
Lo-Fi Version Time is now: January 10th, 2025 - 2:31 AM
