Popping noise after springs and struts install. |
Oct 18, 2007 - 7:21 PM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
So I just got done installing my sprint springs and kyb struts. When I turn my steering wheel all the way to the left or right I get a popping noise from the front driver side. What do you think went wrong?
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Oct 18, 2007 - 7:24 PM |
Did you grease everything up when you put it all back in? If not, you'll get popping and pinging as you turn the wheel.
Oct 18, 2007 - 7:28 PM |
I just greased down the top mounts. What else is there to grease?
Oct 18, 2007 - 7:30 PM |
Did you mount the spring in properly? There is a specific way the spring needs to sit, or else it will spin around until it seats itself.
Oct 18, 2007 - 7:33 PM |
I seated it in the groove right. Maybe I moved it around a lot after my axles kept poping out. Hmm. well is it bad for it to seat itself?
Oct 18, 2007 - 7:39 PM |
Its not "bad", but I would definately get in there and check it out. You don't want that to continue. If it were coilovers it would be different.
Oct 18, 2007 - 7:48 PM |
Alright I'll check it tomorrow, thanks for the info man.
Oct 18, 2007 - 7:51 PM |
Enthusiast Joined May 15, '05 From Toronto Currently Offline Reputation: 4 (100%) |
it could be your mount bearings. Mine had the same problem. bearings are like $40 new from Toyota
Oct 18, 2007 - 8:00 PM |
Enthusiast Joined Apr 24, '07 From lufkin tx Currently Offline Reputation: 0 (0%) |
popping is kinda normal alot of people that installed springs told me they experienced the noise and i did to it takes about 3 days or so and it will stop they just need to settle? correct me if im wrong though??
Oct 18, 2007 - 8:12 PM |
QUOTE popping is kinda normal alot of people that installed springs told me they experienced the noise and i did to it takes about 3 days or so and it will stop they just need to settle? correct me if im wrong though?? Right, popping can be normal within a certain time frame. This is from the springs fully seating themselves and settling in, but if it continues there is something that needs to be addressed. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Oct 18, 2007 - 8:36 PM |
OKay, well I'll just give it about 2 days. If it continues I'll check it out.
Oct 18, 2007 - 8:39 PM |
Enthusiast Joined Jul 29, '03 From north of detroit Currently Offline Reputation: 6 (100%) |
if you didn't torque all the mount bolts (esp the lower ones) to spec, they can actually move. if you torqued them all i wouldn't worry about it, but i've seen it happen before.
-------------------- do you know who i am, mr. worley? |
Oct 18, 2007 - 8:41 PM |
all torqued like theres no tomorrow.
Oct 18, 2007 - 9:53 PM |
oh yeah they pop especially bad on the first day right after you put them on...its scared the crap out of me too when i first heard it
Lo-Fi Version | Time is now: January 10th, 2025 - 1:54 PM |
