oil on spark plug, need help please!!!!! |
Oct 20, 2007 - 9:16 PM |
Enthusiast Joined Aug 21, '07 From Toronto Currently Offline Reputation: 1 (100%) |
So I decided to change my spark plugs this morning after reading a thread regarding spark plugs and this is my concern... there's oil on the old spark plugs... what do you think causes this? Is it the Oil cam ring? if it is... is there a how to on how to fix those? is this a serious problem? would it affect the firing of the spark plugs
? This post has been edited by Jeunesse: Oct 20, 2007 - 11:31 PM -------------------- -Derick
"In hoc signo vinces." In this sign thou shalt conquer." Gone but never forgotten.... |
Oct 20, 2007 - 11:18 PM |
bump... anybody?
Oct 21, 2007 - 12:29 AM |
oil cam ring?
you just need to replace your valve cover gasket. super easy job. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Oct 21, 2007 - 7:57 AM |
The thing is I don't have any other oil leaks, just on the spark plugs. how easy is it to change the valve cover gasket? how much does this oil in the spark plugs affects the performance? thanks for your help guys...
Oct 21, 2007 - 9:38 AM |
QUOTE(lagos @ Oct 21, 2007 - 12:29 AM) [snapback]606886[/snapback] oil cam ring? you just need to replace your valve cover gasket. super easy job. he already answered your question, if you have or not other leaks that's another story, the leak you ask for ( oil on spark plugs ) will be fixed when you replace your cover gasket ( including the gaskets around teh sprak plugs holes ) This post has been edited by Culpable04: Oct 21, 2007 - 9:39 AM -------------------- |
Oct 21, 2007 - 3:34 PM |
ah i see... thanks for the help guys. Im new at this that's why I ask a lot... just trying to learn and not be annoying as hell. Thanks again.
Oct 22, 2007 - 1:42 AM |
Enthusiast Joined Jul 4, '07 Currently Offline Reputation: 0 (0%) |
Dont suggest changing the valve cover gasket yourself unless you know what your doing. Mucking it up could have dire consequences.
Oct 22, 2007 - 9:33 AM |
Enthusiast Joined Sep 29, '05 From Rochester, Massachusetts Currently Offline Reputation: 2 (100%) |
QUOTE(thedrunkfish @ Oct 22, 2007 - 1:42 AM) [snapback]607184[/snapback] Dont suggest changing the valve cover gasket yourself unless you know what your doing. Mucking it up could have dire consequences. ^ yeah but it is mad easy if you need a hand bro, just ask. Imo, change the spark plug tube seals. There are four of them, they sit right under the nuts that hold down the valve cover, they are like 2 bux a piece at the dealer and they could also be your problem. That was my source when I had the same problem. -------------------- The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed? |
Oct 22, 2007 - 10:10 AM |
QUOTE if you need a hand bro, just ask. Imo, change the spark plug tube seals. There are four of them, they sit right under the nuts that hold down the valve cover, they are like 2 bux a piece at the dealer and they could also be your problem. That was my source when I had the same problem. thanks night, That is just what I need... more options and opinions. I don't want to work on my baby and not be sure on what I am doing and just make the problem worst. I want to do it right the first time when it comes to my car that's why I ask a lot of questions and do a lot of ressearches and reading. Again, Thanks for all the help... if anybody has any other opinions, I really really appreciate it if you could share it with me. -------------------- -Derick
Oct 22, 2007 - 2:10 PM |
QUOTE(Jeunesse @ Oct 22, 2007 - 11:10 AM) [snapback]607241[/snapback] QUOTE if you need a hand bro, just ask. Imo, change the spark plug tube seals. There are four of them, they sit right under the nuts that hold down the valve cover, they are like 2 bux a piece at the dealer and they could also be your problem. That was my source when I had the same problem. thanks night, That is just what I need... more options and opinions. I don't want to work on my baby and not be sure on what I am doing and just make the problem worst. I want to do it right the first time when it comes to my car that's why I ask a lot of questions and do a lot of ressearches and reading. Again, Thanks for all the help... if anybody has any other opinions, I really really appreciate it if you could share it with me. i paid 85 bucks. what tha hec* I was tired after changing the clutch... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Lo-Fi Version | Time is now: December 3rd, 2024 - 5:27 AM |
