> 3SGE VS 3SGTE
post Oct 24, 2007 - 8:04 AM
cv7713
Joined Sep 21, '07
From FL
Do these two motors have the same internals? (pistons, rods, etc) I am asking because I know someone giving away a 1st gen 3SGE. Would the internals be able to hold up to an aftermarket turbo setup?
post Oct 24, 2007 - 8:08 AM
Yes you can turbo it. Results may vary on the condition of the motor.
No they aren't the same as 3sgte.
1st Gen 3sge's are old. I am thinking 4th gen Celica. I wouldn't put that in my car nor turbo it w/o a complete rebuild.
This post has been edited by Supersprynt: Oct 24, 2007 - 8:10 AM
post Oct 24, 2007 - 8:20 AM
cv7713
Joined Sep 21, '07
From FL
I see, the bore and stroke are the same but the compression is a bit higher than the turbo. Sad to say the first gen 3S has as much HP as my 5SFE kindasad.gif
Say you were going to rebuild an engine and add a turbo and your choices were a 86-89 3SGE and a 90-95 5SFE, which would you choose?
Wouldn't the "GE" have greater results?
Correct me if I am wrong (seriously) but I can throw in some 3SGTE pistons and keep the rods and crank the same which would give the same specs as a 1st gen 3SGTE?
Are the heads the same?
SORRY FOR ALL THE QUESTIONS, I JUST DO NOT WANT TO MISS OUT ON A CHANCE FOR A FREE ENGINE (WITH POSSIBLE POTENTIAL!)
This post has been edited by cv7713: Oct 24, 2007 - 8:31 AM
post Oct 24, 2007 - 8:59 AM
Yes the GE is a different head, and it will allow for better flow.
post Oct 24, 2007 - 11:02 AM
Kadett
Joined Mar 17, '05
From The Netherlands
1st gen 3S-GE puts out 150 BHP, you could turbo it if you can source the 1st gen 3S-GTE exhaust manifold and such. Dont know about the internals tho. The high compresion rate + turbo would probably take out the (paper) head gasket immediatly.
post Oct 25, 2007 - 4:47 PM
JDcelica
Joined Jan 11, '07
From Rochester, NY
I also have a question on the 3sge, but its the Beams engine. Does the internals match the 3sgte and can you boost a Beams.
[img=http://img56.imageshack.us/my.php?image=signature2fs0.jpg]
post Oct 26, 2007 - 3:02 PM
Yes you can boost it. No they aren't the same internals. It requires proper fuel & cooling additions like turboing any other N/A car.
This post has been edited by Supersprynt: Oct 26, 2007 - 3:05 PM
post Oct 26, 2007 - 4:18 PM
JDcelica
Joined Jan 11, '07
From Rochester, NY
Thanks. Do you think the Beams engine can handle boost
post Oct 27, 2007 - 1:11 PM
Kadett
Joined Mar 17, '05
QUOTE(JDcelica @ Oct 26, 2007 - 11:18 PM) [snapback]608674[/snapback]
Dont think so if you keep the internals as they are, you need to lower the compression if you dont you limit yourself to a small amount of boost. Besides I think its a waste of time. Sell the Beams clip for major $$$ and get a 3S-GTE instead.
post Oct 27, 2007 - 1:22 PM
JDcelica
Joined Jan 11, '07
From Rochester, NY
thanks for the response. glade i dont have any engines yet because im still in the research stages
Lo-Fi Version Time is now: November 29th, 2024 - 5:12 AM
