new engine....not firing!! |
Oct 24, 2007 - 5:56 PM |
Enthusiast Joined Dec 24, '06 From jonesville Currently Offline Reputation: 4 (100%) |
replaced all ignition parts and even got my ecu checked and it was good but still not firing...it might fire 1 time every once in a while but not much at all....timing is also good...the ppl who checked my ecu said there is a possible power surge but cant tell me where from...ne ideas?
Oct 24, 2007 - 8:53 PM |
make sure your igniter is plugged in properly. Have someone wiggle it round while you try to start it, they are sensitive and the pins could be bent a bit.
Oct 24, 2007 - 8:56 PM |
ill try that...but we've plugged and unplugged it and the spark isnt even makin it to the igniter as far as i can tell. thanx
Oct 24, 2007 - 9:52 PM |
Sounds like you got a Bad ground wire going somewhere.
I would recheck your wiring and then ground them. Don't forget to ground the igniter too! |
Lo-Fi Version | Time is now: November 27th, 2024 - 3:52 PM |
