throttle cable |
throttle cable |
Oct 24, 2007 - 10:37 PM |
Enthusiast Joined Oct 9, '07 From Eureka Currently Offline Reputation: 0 (0%) |
my throttle cable is kind of loose and i want to kno how to tighten it up for better throttle respones
Oct 25, 2007 - 8:55 AM |
Theres a nut on the engine side.
Oct 25, 2007 - 2:56 PM |
Enthusiast Joined Jul 12, '07 From London,Great Britain Currently Offline Reputation: 0 (0%) |
Engine side..? i'm having sorta da same problem..good thing blk94gt put up this topic..is the nut on the throttle cable linkage connecting to the throttle body or am i missing smething..?
Oct 25, 2007 - 2:57 PM |
Follow the cable to the end and you'll see a screw & nut that can be adjusted.
Oct 25, 2007 - 3:02 PM |
QUOTE(Supersprynt @ Oct 25, 2007 - 2:57 PM) [snapback]608367[/snapback] Follow the cable to the end and you'll see a screw & nut that can be adjusted. well from inside my car the cable goes from my firewall to this little thing that looks like a throttle body and then it circle around into the throttle connected to the intake manifold |
Oct 25, 2007 - 3:04 PM |
is it a bad thing if its too tight..?or will i just know wen i adjust it to how much it will actually tighten to..?
Oct 25, 2007 - 3:11 PM |
If it's too tight it'll keep your throttle higher than idle.
BLK94GT: what? What thing that looks like a throttle body? -------------------- |
Oct 25, 2007 - 3:41 PM |
i know wot u mean..thanx..
Lo-Fi Version | Time is now: November 27th, 2024 - 4:19 AM |
