![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 15, '07 From Fort Worth, TX Currently Offline Reputation: 12 (100%) ![]() |
QUOTE(kerosene @ Nov 1, 2007 - 8:00 PM) [snapback]610509[/snapback] yes matt, very good idea... but look at 1farad... 1/2 isnt cost effective 1/2 farad is recommended for 500W and below. That's fine, I'm just going to go with that. I get it for like $35. -Matt |
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 4, '07 From US Currently Offline Reputation: 2 (100%) ![]() |
go with one, think ahead of time, doesn't matter if you have more "farads"
QUOTE(kerosene @ Nov 1, 2007 - 11:47 PM) [snapback]610569[/snapback] go with one, think ahead of time, doesn't matter if you have more "farads" You're right, might as well go with a One farad. BTW, I know you put your source from the battery to the cap to the amp, but how do I connect the wires from both sources and put it in the cap? -Matt This post has been edited by GotToyota: Nov 1, 2007 - 11:55 PM |
Good choice on the one farad... choose quality though ^^ rockford isnt any good, go to a shop and get a stinger
one goes to battery (+) and then another wire goes to am (+) and then (-) goes to ground... simplest way... use high guage wire for the caps... look at around 0-4 ![]() this should help you This post has been edited by kerosene: Nov 2, 2007 - 12:23 AM |
![]() Enthusiast ![]() ![]() ![]() Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) ![]() |
capacitors are a waste of money
I know how to hook it up wiring wise, I'm just wondering how you connect the power from the amp and the power going to battery together at the positive post of the capacitor. All I see is a thread hole for a bolt. Do they usually come with the accessory needed to connect them?
-Matt This post has been edited by GotToyota: Nov 2, 2007 - 8:03 AM |
get wires with a little o thing and then you slide it in and tighten bolt
Yeah, I figured it out Kerosene. I actually just got finished installing everything. Here's a pic:
![]() Tell me what you guys think. I decided to mount the cap itself on the side of the box. -Matt |
might rattle just a little, put some padding behind the holders possibly some of that window sealing thing just put it so you dont see it
QUOTE(kerosene @ Nov 2, 2007 - 3:13 PM) [snapback]610725[/snapback] might rattle just a little, put some padding behind the holders possibly some of that window sealing thing just put it so you dont see it I haven't heard it rattling yet, and I tested it with some hard bass. I'll see if I can hear it and if I can then I'll find some padding to put behind it. Does everything look good besides that? -Matt |
yea ^^ you shoulda hid it though... ^^ put it behind the wheelwell (inside) or that little hole on the left side, the red sjust doesnt fit... but its good though, nice job
Nah, I like it beside the box. Plus it's easy to access.
![]() I'd say my setup is offically finished. -Matt This post has been edited by GotToyota: Nov 2, 2007 - 4:45 PM |
for some time.. till you need more umf...
QUOTE(kerosene @ Nov 2, 2007 - 4:55 PM) [snapback]610749[/snapback] for some time.. till you need more umf... Yeah, you're partially right. But for now, this 10" works great. -Matt |
Lo-Fi Version | Time is now: February 18th, 2025 - 3:49 AM |
