Clunking. I know i read up on search. Please Imput. |
Oct 28, 2007 - 11:56 AM |
Enthusiast Joined Jun 13, '07 From Whitby, ON, CAN Currently Offline Reputation: 6 (100%) |
Ok i just installed new tein and kyb's, front is making clunking noise like pop clunk. From what ive read the strut mount might be shot, or the bearing was not properly greased, or the strut mount did not seat properly in the groove. Now the noise i guess is the spring rotating when i turn at slow speeds binding then coming unbound and popping. I need to know if this is a problem because i am goign awway for a week and i need to use my car. If unfixed will this cause major problems or is it just a nusense right now the sounds and all but will be fine if i fix it when i get back please let me know Asap.
Oct 28, 2007 - 3:10 PM |
could be the end links need tightening
Nov 1, 2007 - 1:57 AM |
Enthusiast Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
or replacing.
Nov 1, 2007 - 8:08 AM |
Enthusiast Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) |
mine drove fine for a year or so before i decided to tighten the crap out of the top nut.
Nov 1, 2007 - 1:51 PM |
Enthusiast Joined Apr 26, '07 From Nottingham, UK & sometimes Boston, MA Currently Offline Reputation: 0 (0%) |
Got the same thing at the moment after lowering 40mm. My guess is either overtightening the top nut or not greasing adequately, or a combination of the two. Will go at it on my days off to see if it is indeed the case - hope you get yours sorted mate.
Nov 6, 2007 - 10:58 AM |
I am hopefully going to try and regrease everything this upcoming weekend hopefully it gets rid of this. The sound has gone from the popping to now just a creak but only when the wheel is turned. when the wheel is straight there is no creaking, I think it is just the spring movement along the rubber of the top mount because of lack of grease? im hoping greasing will correct this.
This post has been edited by 94celigts: Nov 6, 2007 - 11:17 AM |
Nov 6, 2007 - 11:05 AM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
I get the rubbing noise from my front as wheel. Only when I turn. I really think its the sprinigs that are trying to get seated in correctly. Not sure though.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Mar 14, 2008 - 1:02 AM |
Enthusiast Joined Feb 17, '07 From wisconsin Currently Offline Reputation: 0 (0%) |
sorry to bring this dead thread back up, but i recently got some KYBs on mine and am now getting the clucks. so what part should i grease and is there a certain grease that works better than others like longer lasting or using less.
Mar 14, 2008 - 1:19 AM |
Oh, if its a clunking its the strut mounts. If its a poping, its the springs not being seated properly. Just grease up your strut mounts and see if that changed anything. If not, invest in soe strut mounts.
Lo-Fi Version | Time is now: November 23rd, 2024 - 8:38 PM |
