> What could cause my upper radiator hose to expand like this?
post Oct 29, 2007 - 4:20 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Anyone have an idea as to why my radiator hose is expanding like this? I just recently had a coolant flush done by Toyota, as well as a water pump and timing belt. Now today I noticed my temperature gauge was just barely above half, so I looked under the hood and noticed that this hose was slightly expanded. Could it be that I need a new thermostat?
-Matt
post Oct 29, 2007 - 4:21 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Is the top hose hot while the bottom is cool or other way around?
**** Photobucket
post Oct 29, 2007 - 4:29 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
thermostat is on the passenger side not drivers side...did toyota put a rat inside the hose?
post Oct 29, 2007 - 4:39 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE(95CelicaST @ Oct 29, 2007 - 4:21 PM) [snapback]609470[/snapback]
Both are hot, but the top one is more warm.
-Matt
post Oct 29, 2007 - 4:48 PM
that hose looks like it's about to burst. I don't think they bled the system properly.
post Oct 29, 2007 - 4:50 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE(Batman722 @ Oct 29, 2007 - 4:48 PM) [snapback]609480[/snapback]
That's what I was thinking. How do you properly bleed the cooling system?
As far as I know (and correct me if I'm wrong), but you let the car get cold, take off the cap, put it on a slight hill (like a driveway), and let it run, and the air bubbles will come up on their own.
-Matt
post Oct 29, 2007 - 4:56 PM
start the car (cold) with the cap off, turn the temp control to hot, fan on high.
fill as needed as the car warms.
dont reuse that hose, i would think the reenforcement cords that are in there are all busted.
post Oct 29, 2007 - 8:51 PM
cHinaman727
Joined Jun 8, '07
From Houston, Texas
mine just popped saturday gg
"You should take a short walk on a LONG PIER"-Crazy Steve
My Celica's SRI
post Oct 29, 2007 - 8:59 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(cHinaman727 @ Oct 29, 2007 - 8:51 PM) [snapback]609551[/snapback]
Just get a new hose and may as well get a thermostat and gasket while your at it/
post Oct 29, 2007 - 10:27 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
its old, thats why. rubber doesnt last forever you know! theres 12-15psi on that hose everytime you drive the car, pretty much the whole time you drive the car, not to mention its over 200F of heat at 13psi.
change both hoses before the ballooning one breaks open and leaves you stranded. use new clamps also please.
post Oct 30, 2007 - 6:25 AM
QUOTE(presure2 @ Oct 29, 2007 - 4:56 PM) [snapback]609486[/snapback]
which temp control. The a/c?
post Oct 30, 2007 - 6:51 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
I'm going to pick up a new hose and thermostat after work, thanks.
-Matt
post Oct 30, 2007 - 6:55 PM
LewFX
Joined Jan 28, '05
let us know how much toyota charged you because mine charged me 16 bux for the thermostat and i paid 12 for the hose
post Oct 30, 2007 - 7:00 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE(LewFX @ Oct 30, 2007 - 6:55 PM) [snapback]609839[/snapback]
I'm at work right now, so Toyota is somewhat close, but it's in the opposite direction of my home, so I'm just going to Auto Zone, which is right on the way home. They said about $30 w/tax for everything. I'd go to Toyota, but I don't want to put much more pressure on the hose.
-Matt
EDIT: BTW, I tried bleeding it, there were no bubbles. So Toyota did everything right. I'll try replacing the hose and thermostat then go from there.
This post has been edited by GotToyota: Oct 30, 2007 - 7:01 PM
post Oct 31, 2007 - 11:16 AM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
I replaced the hose last night. That fixed the problem, so I'm all set. smile.gif
-Matt
post Nov 4, 2007 - 3:49 PM
wrathc5525
Joined Oct 30, '07
From hudson falls ny
it could also be a radiator cap because it is a pressurized cap and if it is broken it will cause a hose to swell up like that
Lo-Fi Version Time is now: December 4th, 2024 - 10:17 PM
