> HKS Hi-power silent exhaust, TOO silent!!
post Oct 31, 2007 - 7:08 PM
DanTheMan
Joined Aug 14, '07
From Sittingbourne, Kent
Hello, i have the item mentioned in the title and its really quiet untill warm, too quiet.
People have mentioned that there should be a screw that i need to undo if i want to pull out the silencer, but i have shone a tourch down the exhaust and cannot see it.
Other people have suggested using a crowbar to rip out the baffle!
Which one is the truth?
post Oct 31, 2007 - 7:17 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
The screw should be visable from outside the muffler tip. It should be on the underside of the tip.
A crowbar will only destroy your muffler, so if thats what you want to do then go for it.
Personally, shouldn't you have had a feeling it was going to be quiet? HKS doesn't call it "silent" for no reason. tongue.gif
**** Photobucket
post Nov 1, 2007 - 3:54 AM
xs94st
Joined Aug 11, '07
From Corona, CA
yea man..if there isnt a bolt there, then there isnt a silencer that you can remove..its built into the muffler.
i know that some have it inside n its built in while others have a removable baffle..looks like you have the latter.
btw, how much that muffler set you back? im lookin for a nice flowin muffler to replace my loud one
Pandelica 2.0 in progress.
post Nov 1, 2007 - 4:49 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
is 98dB silent???
post Nov 1, 2007 - 11:01 AM
DanTheMan
Joined Aug 14, '07
lol i get the general picture, there isnt a bolt so it looks like i gotta live with it untill i can get a new one
i didnt buy the exhaust it came with it
thanks for your advice people
post Nov 1, 2007 - 11:13 AM
Kadett
Joined Mar 17, '05
From The Netherlands
IIRC the HKS Silent hi power has a Resonator/muffler box between the mid section and Exhaust muffler. If you remove that and reweld a straight pipe to it it should sound a bit louder.
post Nov 1, 2007 - 11:34 AM
twitchh17
Joined May 19, '06
From North NJ
QUOTE(Kadett @ Nov 1, 2007 - 11:13 AM) [snapback]610366[/snapback]
noooo bad idea. if youre not running your with a 3sgte DO NOT remove your resonator. i heard from many people that have done this, say that it sounded like mad bumble bees. so unless you want that riced out sound then i wouldnt suggest doing it.
post Nov 1, 2007 - 12:27 PM
Kadett
Joined Mar 17, '05
After reading that, this is probably DantheMan's first Turbo car. And Turbo's are quieter then N/A engine's
I have no box/muffler/etc etc between my (for now) stock DP and rear muffler, and its quieter then my previous ST202 exhaust with midmuffler installed.
This post has been edited by Kadett: Nov 1, 2007 - 12:29 PM
post Nov 1, 2007 - 1:51 PM
DanTheMan
Joined Aug 14, '07
Yeap your right, this is my first turbo car, still getting used to the differences as ive had 6 n/a cars and then this.
post Nov 1, 2007 - 2:39 PM
Kadett
Joined Mar 17, '05
QUOTE(DanTheMan @ Nov 1, 2007 - 7:51 PM) [snapback]610405[/snapback]
Well so you know, the Turbo itself will reduce the noise of the exhaust setup for a good amount, even more if the stock cat is still in place. Getting another muffler wont do the job.
post Nov 2, 2007 - 9:14 AM
twitchh17
Joined May 19, '06
From North NJ
well depending on the piping will decide how loud your car will be. take a look at defgephs exhaust. it's 3" straight with a HKS carbon fiber titanium canister. 4.5" inch tip. thing is a monster. heres a clip of when i use to have the same canister with 2.5" piping with a resonator.
http://www.youtube.com/watch?v=R2fZcuJ2-X4
Lo-Fi Version Time is now: November 27th, 2024 - 9:10 AM
