2 Pages V  < 1 2
> My Interior Photos, ...finally got around to uploading them
post Aug 22, 2003 - 10:30 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
looks good
post Aug 22, 2003 - 11:26 PM
Seth6Gen
Joined Sep 22, '02
From Mammoth CA
your subs look cool mounted there, but im sure they would sound better in a box. Do they rattle? other than that your **** is TIGHT!
post Aug 23, 2003 - 5:18 AM
3TST
Joined Sep 27, '02
From UK
I thought the subs would look good in the parcel shelf especially as they are red and match with the rest of the interior.
Also, they are relatively practical mounted there:
1 - it allows you to see my Amp setup;
2 - leaves the trunk free for bags.
No they don't rattle because the cones are rubber mounted and they are heavy enough to keep the parcel shelf from vibrating.
Only 3 real problems:
1 - they are heavy so the parcel shelf bows in the middle;
2 - because of there size I had to be careful that they didn't hit the rear strut bar when the trunk was closed;
3 - they are very overpowering compared to the rest of the system.
I'm sure you're right, they would sound better in a box in the trunk.
I'm thinking of may be inverting them in the parcel shelf so the cones point into the trunk.
If that doesn't work, then I'll make a box to take my Amps and Woofers and mount it where the Amps are now.
I'll then cut out the parcel shelf and install a perspex window and some lighting.
This post has been edited by vphmc: Aug 23, 2003 - 5:18 AM
2 Pages V  < 1 2
Lo-Fi Version Time is now: December 1st, 2024 - 6:39 AM
