> fuel line, 3sgte or 5sfe
post Nov 2, 2007 - 6:26 PM
y2komar
Joined Sep 21, '06
From New York City
Which fuel lines can be used to connect the 3SGTE fuel rail to the filter? 3SGTE or 5SFE?
on my swap the 3s was cut and the 5s is different.
I beleive I would need the 3s .
does anyone have an idea of what part number that is and how much it will cost.
Or any ideas on how to link the cut 3s with the 5s. I was thinking of a inline filter. ...........
This post has been edited by y2komar: Nov 2, 2007 - 10:40 PM
post Nov 4, 2007 - 6:45 PM
y2komar
Joined Sep 21, '06
From New York City
I was thinking of pairing up the two lines with a additional filter like this. fuel filter
post Nov 4, 2007 - 6:50 PM
y2komar
Joined Sep 21, '06
From New York City
post Nov 4, 2007 - 11:59 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(y2komar @ Nov 4, 2007 - 5:50 PM) [snapback]611163[/snapback]
That's what I did. Even if the 3S line was uncut it wouldn't quite reach.
post Nov 7, 2007 - 2:32 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(WannabeGT4 @ Nov 4, 2007 - 11:59 PM) [snapback]611266[/snapback]
post Nov 7, 2007 - 3:10 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
buy some steel braided fuel line and a couple barbed fittings.
post Nov 7, 2007 - 3:55 PM
QUOTE(x_itchy_b_x @ Nov 7, 2007 - 3:10 PM) [snapback]612113[/snapback]
x2
fuel line is not something you want to ghetto rig. if you have any leaks, your whole car could catch fire.
post Nov 9, 2007 - 9:45 PM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
You can use the 5SFE fuel lines without a problem the 3SGTE. It will be a slight bit longer than is needed, but it isn't an issue at all. The return line is the perfect length to get the job done as well.
I used the bolt from the fuel rail that came off the high pressure line on the 5SFE just to be sure that the inner clearances are exactly the same.
Fasten down the fuel line to the rail with a fresh set of crush washers and you're in business.
post May 27, 2008 - 3:44 PM
trdwasiq
Joined Aug 15, '07
From ATLANTA
i am tryin to find which one is return and which one is feed.. anyone help me out.
its a 3rd gen 3sge
KEEPIN IT LOW... WAP PRODUCTIONS... www.myspace.com/waprod
post May 28, 2008 - 7:22 AM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
well the one going to the fuel rail the the feed line..and you can use the 5sfe fuel line..i have a 3rd gen and thats what i use for the fuel line. yeah just dont getto rig anything cause at the end youll going to have to make it right anyways..
Lo-Fi Version Time is now: November 29th, 2024 - 2:36 PM
