refurbishing wheels, in the meantime performace downgrade |
Nov 3, 2007 - 5:28 PM |
on the back of the tires, what to use to remove the stuck gunk. not even brake cleaner lifts it up....
in the meantime heres my downgrade look. steelies This post has been edited by njccmd2002: Nov 3, 2007 - 8:41 PM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Nov 4, 2007 - 8:59 PM |
Enthusiast Joined Jun 14, '05 Currently Offline Reputation: 1 (100%) |
Gunk? A picture would be very helpful.
Nov 5, 2007 - 6:31 AM |
QUOTE(jdg371 @ Nov 4, 2007 - 8:59 PM) [snapback]611199[/snapback] Gunk? A picture would be very helpful. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Nov 5, 2007 - 8:36 AM |
Enthusiast Joined Feb 8, '06 From Nova Scotia, Canada Currently Offline Reputation: 1 (100%) |
QUOTE(njccmd2002 @ Nov 3, 2007 - 6:28 PM) [snapback]610891[/snapback] on the back of the tires, what to use to remove the stuck gunk. not even brake cleaner lifts it up.... in the meantime heres my downgrade look. steelies -- pic snipped -- short of a sandblaster the only thing that might work with lots of time and patience is a 3M stripping wheel. i tried every product know to the guys at my local UAP with little or no results. it is a mixture of road grime, oxidization and neglect. i used 3M Scotch-Brite discs and pads to get about 75% of the grim off the inside of the wheel. there is a new line of ROLOC products you may also want to try. hope it helps -------------------- |
Nov 5, 2007 - 10:56 AM |
if you look at the pics, thats ats clean as i can. thats almost 90 cleaner than what it was.
ill look into the 3M stripping wheel....thanks... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Nov 5, 2007 - 5:32 PM |
Aircraft Paint Stripper + Paint.
Nov 5, 2007 - 6:40 PM |
QUOTE(jdg371 @ Nov 5, 2007 - 5:32 PM) [snapback]611486[/snapback] Aircraft Paint Stripper + Paint. lol where can i get hooked up! -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Nov 6, 2007 - 8:07 PM |
Enthusiast Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
whith my rims i clean at least the wheels weekly or as close i could manage and would always treat the surfaces to avoid said build up becuase i was in your boat once and it is a pain tot get off. plus its always nice to have clean wheels =) makes a big difference even if the rest of the car is dirty
-------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
Nov 6, 2007 - 8:25 PM |
QUOTE(jason @ Nov 6, 2007 - 8:07 PM) [snapback]611878[/snapback] whith my rims i clean at least the wheels weekly or as close i could manage and would always treat the surfaces to avoid said build up becuase i was in your boat once and it is a pain tot get off. plus its always nice to have clean wheels =) makes a big difference even if the rest of the car is dirty how you get it off in the first place -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Nov 6, 2007 - 8:38 PM |
usually whatever this crap is i get and put into an old spray 9 bottle works for that stuff... ill have to ask about it, but try getting some type of degreaser and spraying it then letting it soak, will also work well if you heat an area of the wheel you wanna clean before you spray n soak, then use a brush, a hard one, but not wire to avoid scratching, and it should loosen it up. put heat on it till its noticably warm-hot to the touch then spray it, let it soak for a minute, then spray some more, let that soak then scrub away, its a big pita
Lo-Fi Version | Time is now: December 2nd, 2024 - 2:10 PM |
