10 Pages V  « < 6 7 8 9 10 >
> Auto 5sfte with dyno vids
post Nov 20, 2007 - 6:35 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
he did strap it down better after that happened
post Nov 20, 2007 - 6:44 PM
6strngs
Joined May 12, '06
From Wilmington, NC
I wanna know the numbers! also, for your loss of boost, check that the vacuum hose going between the turbo housing and wastegate actuator didn't pop off. happened to me and I couldn't boost past about 1 PSI.
post Nov 20, 2007 - 6:46 PM
QUOTE(6strngs @ Nov 20, 2007 - 6:44 PM) [snapback]616069[/snapback]
good call!
post Nov 20, 2007 - 6:51 PM
LewFX
Joined Jan 28, '05
it did pop off, we put it back on, still no boost
post Nov 20, 2007 - 10:12 PM
LewFX
Joined Jan 28, '05
okay, pulled turbo off and found the answer...a stainless oil feed line got cut open somehow and no oil to turbo = dead.....the turbine on the exhaust side isnt even on anymore...thats what the noise in one of the video is and prob why it smoked
post Nov 21, 2007 - 6:36 AM
QUOTE(presure2 @ Nov 20, 2007 - 6:05 PM) [snapback]616035[/snapback]
damn, jeff, your car moved alot on the dyno...
whats the #'s look like..after all, thats what the dyno is all about!!!
NUMBERS OR BAN!!!!!!!!!
post Nov 24, 2007 - 12:40 AM
shin
Joined Aug 21, '04
From New York City
QUOTE(presure2 @ Nov 21, 2007 - 11:36 AM) [snapback]616230[/snapback]
ya better do it man. he'll do it~ HE'LL DO IT! post tem f*ckin #s already!
~*MuH NeW RiDe*~
post Nov 27, 2007 - 5:21 PM
LewFX
Joined Jan 28, '05
dyno sheet:
This post has been edited by LewFX: Nov 27, 2007 - 5:21 PM
post Nov 27, 2007 - 5:29 PM
good job man!
that auto tranny is KILLIN ya.
enjoy the boost!
post Nov 28, 2007 - 12:21 AM
OOBE
Joined Aug 30, '02
From San Juan, PR
Holy drivetrain loss, Margie. laugh.gif Man, screw that. If the same happens to mine when I take it to the dyno, I'll freaking swap in a manual tranny, LOL. tongue.gif
post Nov 28, 2007 - 12:28 AM
cHinaman727
Joined Jun 8, '07
From Houston, Texas
You need....
manual!
"You should take a short walk on a LONG PIER"-Crazy Steve
My Celica's SRI
post Nov 28, 2007 - 10:36 AM
LewFX
Joined Jan 28, '05
woo hoo, craig got the hook ups for a nice used turbo...where else can i try to relocate my oil filter, currently have not moved it and the dp hits it still
post Nov 29, 2007 - 1:34 AM
LewFX
Joined Jan 28, '05
i got a prob...i hooked up everything tonight..started fine except smoked on the manifold, no biggie, i sprayed some pb blaster on it earlier to swap the manifold on the newer manifold. started car up again...ready to test drive...went reverse then forward...car is jerking then died...car wont stay at idle now...what can this be?
post Nov 29, 2007 - 1:50 AM
6strngs
Joined May 12, '06
From Wilmington, NC
check that the map sensor did not disconnect somehow and also check your map sensor and TPS sensor connections for your piggyback.
post Nov 29, 2007 - 2:35 AM
OOBE
Joined Aug 30, '02
From San Juan, PR
What he said. Also, if you can record vids of the car boosting and sneezing, like this: http://media.putfile.com/Celica-Boosting-H...ega-Flow-Intake
Oh, and WOT videos, too..all this, of course, when you get your problems sorted out and you have the time. That would be great. I'm sure people here crave them, too.
We need to get a sticky going for turbo 5S and 7A Celica videos on the multimedia section. No chit-chat or anything, so we can keep it clean and easy to navigate. Just a post with a video URL link, and explanation, followed by the next post. It'll motivate other people to do the same and we can get good memories later on when we upgrade our cars. If no one else agrees, it's cool...I'll just jump off a bridge and end my existence. tongue.gif
post Nov 29, 2007 - 10:10 AM
LewFX
Joined Jan 28, '05
i start the car then it dies...like bogs down without hesitation
post Nov 29, 2007 - 11:08 AM
jesterwr217
Joined Feb 27, '07
From cape coral/ft myers florida
QUOTE(OOBE @ Nov 29, 2007 - 2:35 AM) [snapback]618049[/snapback]
oobe is that your car in the vid cause if so your bov isnt even workn i had the same problem what your hearing is straight compressor surge and compressor surge=bent shaft
BOOST GETS YOU LAID!!!!
post Nov 29, 2007 - 1:00 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(LewFX @ Nov 29, 2007 - 7:10 AM) [snapback]618098[/snapback]
but if you rev it it'll stay running?
post Nov 29, 2007 - 1:01 PM
LewFX
Joined Jan 28, '05
wont let me rev, dies before i can give it gas
post Nov 29, 2007 - 2:05 PM
jcaron9gt4
Joined Feb 26, '07
From Boston, MA
sounds like its not getting enough fuel or soemthing
Lo-Fi Version Time is now: November 30th, 2024 - 8:30 PM
