> Bumper cover removal
post Nov 5, 2007 - 9:07 AM
56willysnut
Joined Nov 29, '06
From Newnan, Ga.
How much of a PITA is it to remove, I need to install new headlights and rework the R/H side sheet metal due to a teenager's crash?
post Nov 5, 2007 - 10:38 AM
QUOTE(56willysnut @ Nov 5, 2007 - 10:07 AM) [snapback]611346[/snapback]
please use the stickys and try your best to post in the appropriate forum.
http://www.6gc.net/forums/index.php?showtopic=28434
post Nov 5, 2007 - 11:21 AM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
its not that bad, if anything is unclear i am going to be removing mine as well as the fenders so shoot me a pm n i can snap some detailed pics for you once you've done it once its pretty easy
post Nov 5, 2007 - 11:58 AM
56willysnut
Joined Nov 29, '06
From Newnan, Ga.
QUOTE(presure2 @ Nov 5, 2007 - 10:38 AM) [snapback]611371[/snapback]
I posted it in the /maintenance area 'cause that's what it is. Not some exterior styling post.
post Nov 6, 2007 - 11:54 PM
celicaST
Joined Jun 23, '05
the 3 bolts on each side holding the bumper to the fender are a pain in the ass to get to
post Nov 7, 2007 - 6:51 AM
QUOTE(56willysnut @ Nov 5, 2007 - 12:58 PM) [snapback]611396[/snapback]
fixing a crash is hardly "maintenance".
since the front bumper is consitered an "exterior" part of the car, and the sticky which contains the bumper removal how to is here, this is where it belongs.
the 3 bolts in the fender arnt bad if you use a good swivel and a couple long extensions.
post Nov 7, 2007 - 7:40 AM
BloodyStupidDave...
Joined Nov 14, '06
From Northampton, UK
QUOTE(celicaST @ Nov 7, 2007 - 4:54 AM) [snapback]611945[/snapback]
They are a little easier if you first remove the water bottle and air intake resonator box.
post Nov 7, 2007 - 8:47 AM
roelamizzle
Joined Aug 8, '06
From Houston
QUOTE(BloodyStupidDavey @ Nov 7, 2007 - 7:40 AM) [snapback]612018[/snapback]
A 10mm deep socket will make life easier as well. The bolts are sticking out just long enough to be a PITA.
Lo-Fi Version Time is now: November 23rd, 2024 - 12:27 AM
