> What would be a better swap?
post Nov 6, 2007 - 1:22 AM
TheMadScientist
Joined Nov 4, '03
From Colorful Colorado
What would be better to swap in, A 3rd gen 3sgte or a 4th gen 3sgte??
1996 Toyota Celica Convertible GT (My 1st Celi,Owned since 2002)
1995 Toyota Celica Coupe GT 3S-GTE
1994 Toyota Celica Liftback GT-Four (RHD/GT-Four conversion)
1990 Toyota Xcab 1UZ-FE Lexus V8, Solid Axle Swap on 35s geared and locked dual Tcases (Rock Crawler)
1990 Toyota 4Runner 5VZ-FE V6 swap, Solid Axle Swap on 38s (Rock Crawler)
1972 Ford F-350 Crew Cab 4X4 Cummins Turbo Diesel (Tow Rig)
1956 Ford F-100 429 / Automatic
1969 Ford Mustang Fastback 429 Tubbed and Caged (Drag Car)
1967 Ford Mustang Fastback 427W / Automatic
1965 Ford Mustang Fastback 347 / 5-speed
post Nov 6, 2007 - 2:52 AM
lubu
Joined Apr 2, '07
From Great Western Plateau
QUOTE(TheMadScientist @ Nov 6, 2007 - 3:22 PM) [snapback]611620[/snapback]
If you can afford it go witht he 3rd gen. If not the 2nd gen still kick a$$ and cheap too.
98% completion
aaRon
post Nov 6, 2007 - 12:17 PM
TheMadScientist
Joined Nov 4, '03
I'm talking about the 3rd and 4th gen 3sgte NOT the 2nd gen
post Nov 6, 2007 - 12:19 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
I would say the 4th gen because its newer. Less miles than the 3rd gen and probably produce a little more power. I would have to say though the wiring might be a little trickier than the 3rd gen for the reason of it being a newer motor. As the motors get newer the more technical the wiring and everything gets. But its up to you, if you've got someone that won't mind with the 4th gen wiring and the money to get a 4th gen clip do it. Less miles more power.
94 Celica gt white (sold)
post Nov 6, 2007 - 12:33 PM
Kadett
Joined Mar 17, '05
From The Netherlands
3rd gen is almost plug and play, has descent amount of power and has aftermarket parts readily available where the 4th gen doesn't have anything. You cant even replace the stock DP with something else unless you do custom work.
post Nov 6, 2007 - 3:49 PM
3rd Gen IMO. Better intercooler, more parts, no ridiculous turbo mounting.
This post has been edited by Supersprynt: Nov 6, 2007 - 3:50 PM
post Nov 7, 2007 - 11:43 AM
jcbass7
Joined Apr 20, '06
From Florida
the IC set up on a 3rd gen is already good to go for a celica. that would be my choice
post Nov 9, 2007 - 12:04 AM
TheMadScientist
Joined Nov 4, '03
Thank You, thats what i was thinking
post Nov 10, 2007 - 2:35 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
The third gen will be the first choice for most people. That said, I've wired up a number of fourth gens and personally swapped one, and I think they are great. The intake manifold design is far superior to earlier versions. The turbo setup is very reliable and makes great power (270whp at 15psi with NO TUNING). The coil on plug ignition is a sweet setup too.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
Lo-Fi Version Time is now: December 2nd, 2024 - 4:12 AM
