Will not start need your help., Driving on I-95 car dies on me... |
Nov 6, 2007 - 6:46 PM |
Enthusiast Joined Nov 6, '07 From pa Currently Offline Reputation: 0 (0%) |
I was driving on I-95 yesterday and my car just lost all power. It died on me and left me on the side of the road. I had the car towed to a friend of mine who works on cars. Today we began to replace fuses and try to start the car. The car will not start. It will not crank at all. The only thing I hear when I turn the key is a clicking noise. Also when I turn the key it burns a fuse. I believe it is the ignition fuse. AM2 I believe. I replaced the fuse and attempted to start the car again. I still do not get any crank and it burns the fuse once again. The car also did not throw a code when it lost power. Any help would be greatly appreciated. Sorry for such a long post.
Nov 6, 2007 - 7:34 PM |
Same thing happened to me in a different car I had; it was the alternator. I'd look at that first.
Nov 6, 2007 - 7:53 PM |
ok thanks a lot I will make sure to check that asap.
Nov 6, 2007 - 7:58 PM |
did you still have lights and everything when your alternator was bad. Because my car still has lights and everything else it just won't crank?
Nov 6, 2007 - 9:03 PM |
if you keep blowing the fuse you might have a shorted out wire somewhere
Nov 6, 2007 - 9:04 PM |
Enthusiast Joined May 5, '05 From New-Brunswick Canada Currently Offline Reputation: 3 (100%) |
Sounds to me like you got a short circuit. The AM2 circuit flows through your ignition switch (key on) and splits off in 4 directions.
-7.5A IGN fuse (turns on EFI relay) -7.5A ST (starter relay) <--- reason it won't crank, no AM2, no power here -all injectors in parallel -igniter I know the two 7.5A fuses don't burn up so go down the line and check all the wiring for your injectors and your igniter. The AM2 circuit is black/orange (black with orange stripe) -------------------- ----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy |
Nov 6, 2007 - 9:18 PM |
Enthusiast Joined Feb 18, '06 From NB, Canada Currently Offline Reputation: 12 (100%) |
QUOTE(K-ESD @ Nov 6, 2007 - 10:04 PM) [snapback]611888[/snapback] Sounds to me like you got a short circuit. The AM2 circuit flows through your ignition switch (key on) and splits off in 4 directions. -7.5A IGN fuse (turns on EFI relay) -7.5A ST (starter relay) <--- reason it won't crank, no AM2, no power here -all injectors in parallel -igniter I know the two 7.5A fuses don't burn up so go down the line and check all the wiring for your injectors and your igniter. The AM2 circuit is black/orange (black with orange stripe) ya f'n nerd -------------------- -Rémy 02 SiR, 08 250R |
Nov 7, 2007 - 12:06 AM |
Ok I will check that tomorrow. Thank you very much for the information. Hopefully this will solve the problem. I will let you know tomorrow as soon as I check it. Thanks again.
Nov 8, 2007 - 7:55 PM |
Still in the process of checking everything. I have a tight schedule with work. Have to have my wife drive me to work every morning because I am stuck without a car. I will post and tell you if this worked thanks again.
Nov 13, 2007 - 2:59 PM |
Ok so I have some information now. as soon as I turn the ignition on the 30 AM2 fuse burns. Not the 7.5. anyone know what this is. I also have juice in the starter. I put the tester on the starter and I have juice there. Any help is greatly appreciated. I have to get this vehicle running again. Thanks again.
This post has been edited by Grk_celica94: Nov 13, 2007 - 3:06 PM |
Lo-Fi Version | Time is now: January 13th, 2025 - 4:39 AM |
