3 Pages V   1 2 3 >
> Polk subs and kicker amp, wat yall think of this setup?
post Nov 7, 2007 - 1:34 AM
CelicaST_CALI
Joined Feb 28, '07
Well i thought id make my own custom box but now im thinking not,what do u guys think of these,there reviews are great,but id need to get a big amp to power them.Concerns,questions,comments?
http://www.crutchfield.com/App/Product/Ite...2122&tp=112
Details:
*ported enclosure with two 12" db Series subwoofers
*3/4" MDF construction with front-panel ABS trim
* polypropylene woofers with Santoprene rubber surrounds
* 2-ohm mono impedance (1 set of heavy-duty binding posts)
* Power Port venting technology
* frequency response: 27-200 Hz
* power handling: 750 watts RMS (1,500 watts peak power)<<<<<<<<<<<
* sensitivity: 103 dB
* 34-1/4"W x 16-1/4"H x 17-1/4"D1 x 13-1/4"D2
* warranty: 1 year
http://www.crutchfield.com/App/Product/Ite...7501&tp=115
# mono subwoofer amplifier
# 375 watts RMS x 1 at 4 ohms (750 watts x 1 at 2 ohms)
# variable low-pass filter (50-200 Hz at 24 dB per octave)
# variable bass boost (0-18 dB at 40 Hz)
# subsonic filter (12 dB at 25 Hz)
# wired remote bass level control
# Class D design
# CEA-2006 compliant
# speaker-level inputs
# preamp outputs
# fuse rating: 40A x 2
# 4-gauge power and ground leads with 80-amp fuse recommended — wiring and hardware not included with amplifier
# 14-11/16"W x 2-5/16"H x 9-5/8"D
# warranty: 2 years
This post has been edited by CelicaST_CALI: Nov 12, 2007 - 10:23 PM
BANNED. for life, you moron.
post Nov 7, 2007 - 2:14 AM
spolski07
Joined Jul 7, '06
From Los Alamos, NM
sounds like a great sub...
heard a lot of good things about polk though
butttttttt im not a fan, id rather have a alpine type x for a jl w6 or w7
post Nov 7, 2007 - 10:17 AM
94celigts
Joined Jun 13, '07
From Whitby, ON, CAN
MTX Cheaper and same quality. Polks are very nice though but are pricy. I used to work at Futureshop. I would only go with MTX, Image Dynamics, Infinity (higher quality not entry level). JL or POLK... no others.
MTX IMO is the best for the price though
post Nov 7, 2007 - 11:25 AM
tim86
Joined Oct 31, '03
From Orlando, Florida
they look nice... ive also heard great things about polk... whatever sub you get, just match it with the correct power and youll be good smile.gif I like that box and sub combo tho
post Nov 10, 2007 - 6:09 PM
CelicaST_CALI
Joined Feb 28, '07
bump
post Nov 11, 2007 - 5:29 PM
CelicaST_CALI
Joined Feb 28, '07
im thinking of powering them with this,good?:
http://www.crutchfield.com/App/Product/Ite...b=detailed_info
post Nov 11, 2007 - 6:54 PM
spolski07
Joined Jul 7, '06
From Los Alamos, NM
QUOTE(CelicaST_CALI @ Nov 11, 2007 - 5:29 PM) [snapback]613281[/snapback]
thumbsup.gif thumbsup.gif i like that amp
post Nov 11, 2007 - 7:48 PM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
FlickR
post Nov 11, 2007 - 7:57 PM
CelicaST_CALI
Joined Feb 28, '07
wow thats cool blinky^^^^^ wat subs and amps are those?how do they sound,i have been reading reviews for these subs and there all 5.0 outta 5.0,only prob is how big they are.
This post has been edited by CelicaST_CALI: Nov 11, 2007 - 7:57 PM
post Nov 11, 2007 - 8:54 PM
BLINKYxMUNKEY
Joined Nov 12, '03
Two 12in. Polk MM2124 series running off the Polk C300.2 amp. Sounds nice and crisp. Exactly what I needed. Box was custom built to fit snug in the trunk. I have Polk db6750 components (front) and Polk db650 coaxial running off of the Polk C400.4 amp.
FlickR
post Nov 11, 2007 - 9:49 PM
CelicaST_CALI
Joined Feb 28, '07
sounds loud^^^wat do u think of the wiring of polk?
post Nov 11, 2007 - 10:09 PM
DaCCelica94
Joined Oct 20, '07
From North Charleston, South Carolina
i was lookin at the pic of that kenwood amp and the specs and your gonna run into some probs if you buy it because your going to be trying to run two subs off a mono channel amp.
post Nov 11, 2007 - 10:13 PM
BLINKYxMUNKEY
Joined Nov 12, '03
There are no problems with running 2 subs off of one mono amp. My friend has been running his for over 3 years now, problem free.
This post has been edited by BLINKYxMUNKEY: Nov 11, 2007 - 10:14 PM
FlickR
post Nov 11, 2007 - 10:17 PM
DaCCelica94
Joined Oct 20, '07
what i meant was you wont get as much power to both subs, i would prefer buying a 2 channel amp but thats just me
post Nov 11, 2007 - 10:27 PM
CelicaST_CALI
Joined Feb 28, '07
ya i thought of that,but thats around 600rms per sub isnt it??
This post has been edited by CelicaST_CALI: Nov 11, 2007 - 10:30 PM
post Nov 12, 2007 - 12:58 AM
spolski07
Joined Jul 7, '06
From Los Alamos, NM
if you wire them correctly you will actually get more power out of an monoblock amp for 2 subs.
the amp see's the 2 dual voice coil subs as a 1 ohm impeadence instead of an 2 ohm impeadence, so you get more power out of the amp
post Nov 12, 2007 - 1:08 AM
CelicaST_CALI
Joined Feb 28, '07
wat do u mean wire right,just buy high gauge wire?that wiring diagram is correct right?
post Nov 12, 2007 - 9:29 PM
CelicaST_CALI
Joined Feb 28, '07
ok well i realized that these subs are 750rms TOGETHER so thats only 325 a peice....so i need to downgrade my amp.check orginal post
post Nov 12, 2007 - 10:29 PM
cHinaman727
Joined Jun 8, '07
From Houston, Texas
my friend just got two 1200 w 12's from kenwood and a proaudo 2200 w for 350 install free XD
"You should take a short walk on a LONG PIER"-Crazy Steve
My Celica's SRI
post Nov 12, 2007 - 10:52 PM
CelicaST_CALI
Joined Feb 28, '07
and wat does that have to do with this....that lucky bitch...
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: November 23rd, 2024 - 10:10 PM
