> RWD conversion... what would it take?
post Nov 11, 2007 - 2:41 AM
mandrek
Joined May 4, '05
From western MD/NOVA
I have been pondering doing this for some time, but have honestly got no idea were to start.
Im going to go turbo on my 7a this winter, and know that im going to be replacing the auto tranny later this up coming summer.. Oh btw I drive a 95 St Auto..... I have seen some members here doing the GT4 conversion.. And that got me thinking... if im going to be doing a tranny swap, and I want to get into drifting soon too.. (And im going to do a rear disk brake conversion soon too) I might as well try to knock it all in one fell swoop..
im not afraid of tackling a project of this size. And I know that if I prep myself correctly I should not have any trouble doing either..
My question is. Where would I find the drive train that would fit my car?? ive poked around google and such. but not found much at all.. Either im using the wrong search functions. Or just not finding what it is I want..
Any help or advice that you (the community) can provide would be much appreciated..
post Nov 11, 2007 - 3:03 AM
Harold_Fastwaker
Joined Aug 8, '07
From United States
Well, this thread will most likely be locked.
But, the gt4 rear end is somewhat strong. But I have no idea how long it would last on strictly RWD.
So here is what you do.
Ford 8 rear end and chop it to size then weld back together. Will be strong and work out well. Then go put a W58 trans in with your floor hacked up and have a custom drive shaft made to spec. Move your steering rack, create an engine cradle and weld that in. Then figure out how to make the steering work properly without bump steer. Fab up your rear end with a LSD and new gas tank. You will need to run a fuel cell so that will need to be mounted as well. 6 point cage/roll bar would be a good thing as well to stiffen up the chassis from all the hacking.
Thats the list I have so far in basic terms. But then I realized hey, why not put this money into a 7 for the weekend car instead of hacking my DD.
This post has been edited by Harold_Fastwaker: Nov 11, 2007 - 3:05 AM
post Nov 11, 2007 - 3:18 AM
mandrek
Joined May 4, '05
why woud the thread be locked?
any ways, yeah.. kinda the reason why i'd like to go with just using the rear end of the GT4..
my goal on the 7Afte.. is 200whp at the first.. then posibly doing a compleat bottom end build out, with a 4A head.. w/ about 300-350 rwhp being my end goal. from what ive seen.. the gt4 drive trane should be able to handle it NP.... any idea were i might find one such drive trane?
post Nov 11, 2007 - 5:56 AM
Hanyo
Joined Aug 16, '03
From Bay area
the gt4 rear end holds up to 600-ish hp. (see tufy's rear differential thread)
but using the gt4 rear end is not as easy as you think it will be. Your better off building everything from scratch.
please use the search function. I've answered and wrote the same thing pretty much 10 times.
My recomendatoin to you is to use the japanese lexus engine and transmission. The 4age black top that has a rear wheel drive transmission. You can also get the rear suspension also and weild it up. You will just need to get a custom drive shaft and your gold.
But word of warning, suspension work require alot of knowledge. If you set the camber/toe-in incorrectly can cause your car to lose control in high speeds. I'm not saying if you go past 60 mph you car will automatically flip.
post Nov 11, 2007 - 6:20 AM
Kadett
Joined Mar 17, '05
From The Netherlands
QUOTE(Hanyo @ Nov 11, 2007 - 11:56 AM) [snapback]613163[/snapback]
I think your wrong at this point.
The GT4 is a 50/50 AWD car, so 50 percent is going to the back. With tufy's 600 bhp that would mean a maximum of 300 before shattering your rear diff.
post Nov 13, 2007 - 4:03 AM
Harold_Fastwaker
Joined Aug 8, '07
From United States
QUOTE(Kadett @ Nov 11, 2007 - 8:20 AM) [snapback]613167[/snapback]
I knew somebody would understand that.
I dunno about the whole, build it all from scratch thing. That cost would sky rocket your overall cost. It would be "easier" to use the GT4 rear end with a rebuild on it. Weld that up, then have some custom axles made and a drive shaft. Put in a stronger diff. and you should be fine.
But as stated, there are quite a few locked threads on this topic. Run a search from it covering each subsection and you will have a lot of posts show up.
Lo-Fi Version Time is now: January 10th, 2025 - 10:57 AM
