> Do your brakes on your st suck?, Almost slammed into my GTZ
post Nov 13, 2007 - 7:35 PM
zero07
Joined Apr 15, '07
From san antonio tx.
I was following behind my wife yesterday when we came over a hill, and there was a huge line of cars stopped at a light. Of course i saw her hit her brakes hard and so did i, fortunately ABS and four wheel disc brakes on my Galant GTZ stopped her and my little girl from slamming into the car in front of them. Unfortunately i locked up and started sliding right for the back of them, i steered hard to the left so that i wouldnt hit them, instead was gonna hit the curb dead on. Right as i was about to hit it, tires screeching, smoke and all i cut it back to the right a little and hit hard, luckily just curbed the rim pretty good and left with a small vibration. Time to upgrade my brakes
post Nov 13, 2007 - 7:41 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
**** Photobucket
post Nov 13, 2007 - 7:43 PM
j0e_p3t
Joined Dec 8, '05
From torrance/carson, ca
i converted my drums to disc brakes. that helped out a lot. and good tires too.
post Nov 13, 2007 - 7:45 PM
phonex98
Joined Mar 25, '06
wouldn't than an upgrade of driver (pump non abs breaks) and tires be in order ? Seems like your brakes had no problem doing their job...
----- '94 ST hatch --- Yellow -----
post Nov 13, 2007 - 7:49 PM
zero07
Joined Apr 15, '07
Pump? laugh.gif Guess you've never been in this situation before, no time for that, would have hit her for sure. Tires are good
post Nov 13, 2007 - 7:56 PM
94CelicaDragon
Joined Oct 1, '07
From Sacramento, CA
My break's are alright. My rotor's are warped though, and my driverside front brake Is makeing this 'cckkk' noise, like the pad Is worn down and It's metal on metal. Time for me to upgrade.
post Nov 13, 2007 - 8:01 PM
zero07
Joined Apr 15, '07
Yeah ill probably do what joe p3t did.
post Nov 13, 2007 - 8:02 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Maybe your brakes just need to be inspected, make sure they're not out of adjustment. I can't say I don't have any problems with my ST, I'm in need of new rotors, pads, drums and shoes all around. But I also haven't had a time where I've had to slam on my brakes like that.
post Nov 13, 2007 - 8:03 PM
zero07
Joined Apr 15, '07
I hear its not too hard to do the gt conversion on an st
post Nov 13, 2007 - 8:06 PM
j0e_p3t
Joined Dec 8, '05
yeah, you're suppose to pump on the brakes when you feel them about to lock up. but i've been in a similar situation and that would've made things worse. i had to pull my e-brake and downshift to 2nd so the engine brake helped out. it might not good for your tranny and what-not but its a lot better than rear ending your wife and daughter. st brakes do suck. upgrade your rotors and pads and even a rear disc brake conversion if you want. pretty simple to do.
post Nov 13, 2007 - 8:08 PM
a) you should always PUMP non-abs brakes......thats like in driving 101 back in highschool....this is a BASIC driving technique.
when you lock up wheels you LOSE control...pumping (or active abs) allows you to control your car and put it where it needs to go.
b) brakes are only as good as your tires
c) ST brakes are sufficient....good pads, quality rotors (brembo blanks), fluid flush within the last 2 years.
d) increase following distance
This post has been edited by playr158: Nov 13, 2007 - 8:10 PM
zero07
Joined Apr 15, '07
Im really gonna look into that, what parts would i need from the gt joe p3t/ no offense player158 but like i said before no time for that (pumping)
This post has been edited by zero07: Nov 13, 2007 - 8:10 PM
post Nov 13, 2007 - 8:22 PM
GriffGirl
Joined Feb 7, '07
ABS isn't always the best either... there are times like in extreme snow or ice or bad mud that you might actually NOT want the ABS to be active and you want to have the control over your brakes yourself (i.e. pumping). You probably don't get much of that in San Antonio though, huh smile.gif And no, there isn't always time to pump, but in cases where there isn't time to pump the brakes your brakes wouldn't lock up anyway.
4 wheel disk brakes will be better brakes, but will still lock up w/out ABS if I'm not mistaken.
post Nov 13, 2007 - 8:41 PM
phonex98
Joined Mar 25, '06
People are suggesting better tires/pumping zero because your brakes did their job... they stopped the tires....
post Nov 13, 2007 - 10:57 PM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
down shifting aggressively + pumping is my emergency stop technique. (in my Paseo with drum brakes, I got 4disk ABS in the Celi)
down shifting helps big big time since you get resistance at the wheels + as a bonus more vacuum for the brake booster (more braking power). If you're automatic, well you wouldn't be going fast in the first place tongue.gif
You do not lack braking power, you locked up all wheel. To stop faster, first you need better tires and a better braking technique (no disrespect). Then after, if it isn't enough, do a RW disk conversion.
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Nov 13, 2007 - 11:31 PM
oh did i mention the main reason.....don't follow so close...
there is always time for pumping if you lock up your brakes, you just aren't used to the situation/at that level of response yet.
This post has been edited by playr158: Nov 13, 2007 - 11:31 PM
post Nov 14, 2007 - 2:14 AM
xs94st
Joined Aug 11, '07
From Corona, CA
i slid today..i got no abs n had no time to pump anything. i duno why the guy stopped..it was a green light and nothing going on n no traffic.
Pandelica 2.0 in progress.
post Nov 14, 2007 - 6:59 AM
Helix
Joined Apr 17, '07
From Greece
I believe that st brakes are quite sufficient, given that my st had standard rear disks and ABS.
post Nov 14, 2007 - 7:32 PM
celicamike
Joined Dec 26, '05
From So Cal
Your brakes worked perfectly, actually, a little too good since they locked up. There is no lack of clamping power from your stock brakes, but ABS would be better.
post Nov 14, 2007 - 8:06 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
QUOTE(j0e_p3t @ Nov 13, 2007 - 5:43 PM) [snapback]613904[/snapback]
you mean I converted! hehe
Lo-Fi Version Time is now: December 3rd, 2024 - 2:55 PM
