3 Pages V   1 2 3 >
> Sprint springs not that great?
post Nov 14, 2007 - 2:37 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
So today after class theres this turn that takes me on the on ramp to 610. Well the light was green so i figured I could push my car little around the corner. Corner was semi sharp. I lowered my car on sprint springs with kyg gr2s. Well I only took the turn at about 40 mph and I had body roll like theres no tomorrow. I have the stock gt front strut bar and i know that does crap, but how can i eliminate this body roll. I know suspension technique sway bars will do, but will i also need the front and rear strut bars with the sway bars? Or can I just do the sway bars and not have to worry about the strut bars?
94 Celica gt white (sold)
post Nov 14, 2007 - 2:42 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
i can take corners at 60 with ease with my sprints...i did update the sway bars tho and get a 3 point strut bar in the front
post Nov 14, 2007 - 2:44 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Well that doesn't help. j/k. what site would be good to check out for the best deal on the sway bars. So far racinglab has the cheapest price.
post Nov 14, 2007 - 3:18 PM
LewFX
Joined Jan 28, '05
we had a gb on these about a year ago from nopi
post Nov 14, 2007 - 3:44 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
dang too late for me. its all good, I'll just order them from racinglab.
post Nov 14, 2007 - 4:11 PM
GR2s are OEM replacements, not a performance product.
Having only springs basically only helps in lowering the center of gravity.
post Nov 14, 2007 - 4:32 PM
LewFX
Joined Jan 28, '05
thatsd true too, i do have bilsteins which are performance struts
post Nov 14, 2007 - 6:19 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE(LewFX @ Nov 14, 2007 - 4:32 PM) [snapback]614184[/snapback]
Where did you find a set of Bilstein's at?
-Matt
post Nov 14, 2007 - 7:54 PM
azian_advanced
Joined Apr 18, '05
From Calgary
a good set of struts are the factory sport suspensions... they're decent enough to take some cornering, imo. i also upgraded to RSR springs from stock (in the rear) and it barely did anything...
get a good front strut bar, it will make a huge difference.
This post has been edited by azian_advanced: Nov 14, 2007 - 7:55 PM
post Nov 14, 2007 - 8:05 PM
LewFX
Joined Jan 28, '05
try the sway bars and strut bars and see te difference
post Nov 14, 2007 - 9:05 PM
DangerboyJr
Joined Sep 30, '07
From Ontario
QUOTE(Supersprynt @ Nov 14, 2007 - 4:11 PM) [snapback]614175[/snapback]
I was going to say that if nobody else did.
If you want a performance Strut. Get the AGX's
post Nov 14, 2007 - 9:16 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Where can I find the Bilstein's and the AGX's? I've looked on Ebay and can't seem to find any.
-Matt
post Nov 14, 2007 - 9:27 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
the cheapest you can get them check out ajusa.com
ill get the suspension tech sway bars first.
post Nov 14, 2007 - 9:57 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
I just looked at them. They are much more expensive then the GR2's.
-Matt
post Nov 14, 2007 - 9:59 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
yes, but from what others say well worth it. gr2s are oem replacement. I got gr2s because of the price and figured if i lowered the car and added sway bars and strut bars it will be just fine.
post Nov 14, 2007 - 10:11 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
I had GR2's on my Supra, and I thought they were great. I had Eibach lowering springs, GR2 shocks, and a standard front strut bar. The car handled great for being 3500lbs.
I think the Celica will be fine with GR2's. No point on spending hundreds more on a daily.
-Matt
post Nov 14, 2007 - 10:14 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
I guess you're right, but don't you ever get the need to just feel the what the car can do? its no fun if you cant take corners or accelerate better than stock right?
post Nov 14, 2007 - 10:25 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE(bccentaur3 @ Nov 14, 2007 - 10:14 PM) [snapback]614307[/snapback]
Upgrading the shocks/struts will definitely make it better then stock.
I got better handling when I upgraded to bigger wheels.
-Matt
post Nov 14, 2007 - 10:27 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
I think the biggest wheel size i would ever go would be 16s regardless of the wheel gap.
post Nov 14, 2007 - 10:30 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE(bccentaur3 @ Nov 14, 2007 - 10:27 PM) [snapback]614318[/snapback]
No, I upgraded to 16's with a smaller tire from 15's with a bigger tire. The difference right there was pretty huge. Can't wait to see what new springs/shocks will do.
If I get enough Christmas $ I might even get some new sway bars.
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: December 12th, 2024 - 3:31 PM
