> what size wheels/tires/offsets are you running?, any clearance issues?
post Nov 14, 2007 - 11:57 PM
6strngs
Joined May 12, '06
From Wilmington, NC
I'm trying to decide between some wheels that are 17x7.5 with a 45 offset, or some 17x8 with a 46 offset. for tires, probably 225/45/17 but I'm kinda curious if 235/40/17 tires would fit.
my question is, what size wheels, tires, and offsets are you guys running and do you have any issues with rubbing? and would you say you have a lot of clearance or very little in terms of being able to fit something bigger? also mention if you're lowered or not.
post Nov 15, 2007 - 12:00 AM
gt_driFFter
Joined Nov 29, '04
17x8 with a 35 offset, lowered considerably and I only SLIGHTLY rub the inside plastic of the fender. But that's also probably due to it not being completely secured. That wheel size/offset gives our cars an AWESOME stance.
235/40/17 are the tires
post Nov 15, 2007 - 12:15 AM
jdg371
Joined Jun 14, '05
WIDEST tires the 17x8 can hold would be some 245/40s
post Nov 15, 2007 - 12:28 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(gt_driFFter @ Nov 14, 2007 - 9:00 PM) [snapback]614364[/snapback]
so, if I did 235/40/17 tires on a 17x8 with a 46 offset I'd probably rub unless I got a 10 or 15mm spacer to make the offset 36-31? the wheel offset guide says that we need a 40mm offset for 8.0" wide rim on a lowered car. you don't have any issues with the rims sticking out too far and hitting the outter side of the fender, do you?
post Nov 15, 2007 - 1:34 AM
95celgt
Joined Oct 5, '03
From South TX.
i have 17x7 42 offset, tire size 215/45/17, the wheels look way too tucked in the back but the front rub the fender lip on the tein s-techs.
GTdrifter, im about to buy those hornets, but im going 17x7 in the front and 17x8 in the back, i demand more pics they look sweet
post Nov 15, 2007 - 3:45 AM
SteveHall
Joined Nov 8, '07
From Surrey, England
I don't know if any of you have been to this website before:
http://www.carbibles.com/tyre_bible_pg2.html
but if you go about 1/3 the way down the page there is an excellent tyre size calculator.
I've recently gone for 215/45/17 Front and 225/45/17 rear under stock suspension. but still waiting on delivery.
post Nov 15, 2007 - 10:45 AM
gt_driFFter
Joined Nov 29, '04
The rims do not stick out to far. In the front, they are perfectly flush, in the back they are only slightly tucked. It has a wide stance, and I love it.
This post has been edited by gt_driFFter: Nov 15, 2007 - 10:47 AM
post Nov 15, 2007 - 11:43 AM
jdg371
Joined Jun 14, '05
A great wheel with those specs 17x8 35 Offset would be the 5Zigen FN01RC, 16LB and well built. I have these myself, sits flush in the front and very very slightly tucked in the rear. 215/45 are a stretch but 225/45 would be sweet.
check out www.1010tires.com for calculations with tire size vs stock size.
post Nov 15, 2007 - 5:50 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(jdg371 @ Nov 15, 2007 - 8:43 AM) [snapback]614470[/snapback]
yeah... but they cost about $180 per wheel and I don't like the way the skinny spokes look that much. I think I'm just gonna get some cheap 17x7 with 225/45 tires and then save up and later on get something really nice like Volks or Gram lights and then I can swap my 225 tires over onto them. those at least would be worth putting spacers and longer studs on if I had to. I don't see it being worth going to all that trouble for some cheapo $130/each wheels.
in case anyone was wondering, these are the wheels I was considering at first. they are Volk Evolutions. old school discontinued volks! smile.gif was getting a hella good deal on them at only $200, but 3 were curbed, and one was cracked in the barrell, they were 17x7 with a 5x100/4x100 bolt pattern. and they were silver like in the picture. I decided that by them time I fixed the cracked one, fixed the curb rash on the other 3, and had them powder coated a color I liked, I could've just bought some pretty nice other wheels. plus I don't really like the style, I just wanted them cause they're volks biggrin.gif
So then I was deciding between these (the 17x8 with 46 offset)
and these (17x7.5 45 offset)
but I wished those were more bronze like this intstead of gold: (same MB wheel in different color)
so now I'm still looking. but I think I'm gonna lower the car first so I won't need a different offset before and after lowering since I'll allready be lowered.
post Nov 15, 2007 - 6:16 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
With all of the offsets above you would NEED to run spacers. Those would be ideal offsets for a Subaru, but not us. +42mm at most. You want to find wheels that are between +35 ~ +42 Anything lower than +35 would stick outside the fender and anything higher than +42 would be sunken in too much and would probably rub on the suspension without a 15mm spacer.
**** Photobucket
post Nov 21, 2007 - 6:49 AM
prowzee
Joined Jan 17, '07
From (CA) orange county
205 50 16 + 16 offset
This post has been edited by prowzee: Nov 21, 2007 - 6:49 AM
Lo-Fi Version Time is now: January 10th, 2025 - 9:48 AM
