> 7afte....continued
post Nov 16, 2007 - 12:05 AM
jesterwr217
Joined Feb 27, '07
From cape coral/ft myers florida
ok so my fuel pump went out ...prolly cause of my setup with the fmu and check valves but now since that has happened i decided to do the fuel setup right ... the past 2 days ive removed the fmu and check valves and added in my mr2 2 bar map sensor 315cc (lime green) supra injectors and im waiting on getting my new fuel pump it should be here this weekend but if lagos manny or nuke or neone else that knows what theryre talkn about lemme know if ive left anything out hopefully when the pump gets in im gona start the car and do some temporary tuning with my wideband and safcII lol
BOOST GETS YOU LAID!!!!
post Nov 22, 2007 - 9:13 AM
jesterwr217
Joined Feb 27, '07
alrighty well got eveything in and learned a good lesson ...dont use electrical tape to hold wires together in a gas tank....but got the new fuel pump in and started the car the new injectors are makn it run really rich but i parked the car drained the oil fixed the oil filter relocation kit and ordered a new oil return line kit to replace my ghetto one so hopefully that will fix the smoking problem under boost
post Dec 4, 2007 - 11:46 AM
jesterwr217
Joined Feb 27, '07
ok got everything in and it was running ok till one of my new injectors sprung a leak frown.gif so tomorrow b4 work im gona get up and replace the seals on it then hopefully ill get to drive it around the neighborhood and tune out some of this extra fuel due to the bigger injectors
Lo-Fi Version Time is now: December 1st, 2024 - 3:35 PM
