5 reasons why not |
5 reasons why not |
Nov 16, 2007 - 3:54 PM |
can i get 5 reasons why not, in regards to safety..... I have some rims i can use and this seems to be an alternative.
http://cgi.ebay.com/ebaymotors/WHEEL-ADAPT...1QQcmdZViewItem -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Nov 16, 2007 - 4:04 PM |
tacky, ugly, cheesy, "ricey", and primarily for 80s hondas
Nov 16, 2007 - 4:08 PM |
Enthusiast Joined Jun 5, '06 From Hayward,CA Currently Offline Reputation: 4 (100%) |
QUOTE(GriffGirl @ Nov 16, 2007 - 4:04 PM) [snapback]614875[/snapback] tacky, ugly, cheesy, "ricey", and primarily for 80s hondas ??? they are just wheel spacers... im sure many people have these on celicas considering the stock wheels are so narrow. |
Nov 16, 2007 - 4:22 PM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
It actually allows you to use 5x114 wheel lug patterns. I say no use what you got. Just get rims with the right offset, and you'll be good to go.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Nov 16, 2007 - 8:10 PM |
thats what im saying i have a pair of 5 x 114 i can use. Is it safe tough..
Nov 16, 2007 - 8:23 PM |
I thought they were those things that make your wheels stick way the hell out from the sides of your car.
Nov 16, 2007 - 10:40 PM |
Yeah thats what it looks like though. I wouldn't do it man. Sell the rims you got and get some that actually fit your car with the right offset.
Nov 16, 2007 - 10:58 PM |
Enthusiast Joined Apr 24, '07 From lufkin tx Currently Offline Reputation: 0 (0%) |
yeah well they might make stock wheels widen out BUT u are gonna put aftermarket wider rims on these and it will look like those gold spoked 13 inch rims that u see on geo metro's
Nov 17, 2007 - 1:27 AM |
Enthusiast Joined Jun 14, '05 Currently Offline Reputation: 1 (100%) |
Why would it stick out? We don't have the specs to his Wheels....
1) Tacky, having these just looks like you cheaped out looking for the right wheels. 2) Unsafe, I have heard numerous stories about wheels coming off. Spacers scare me, the most I would use is a 5mm, seing that spacers scare me.. adapters frighten me! 3) In regards to safety. You will be adding stress to your factory studs, with this installed the studs will be stressed out due to the extended [adapter] lenght of the wheel from the base.. 4) The possibility that with the adapter will increase the lenght from the hub causing a would be perfect wheel to stick out past your fender |
Nov 17, 2007 - 2:30 AM |
Enthusiast Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
QUOTE(jdg371 @ Nov 17, 2007 - 7:27 AM) [snapback]614988[/snapback] 2) Unsafe, I have heard numerous stories about wheels coming off. Spacers scare me, the most I would use is a 5mm, seing that spacers scare me.. adapters frighten me! 3) In regards to safety. You will be adding stress to your factory studs, with this installed the studs will be stressed out due to the extended [adapter] lenght of the wheel from the base.. I have to disagree about these points. If you use a correct kit/brand (like H&R) you will recieve longer studs with the kit. I have 15mm and 20mm spacers and I drive my car 'hard'. No problems whatsoever the past 18 months. -------------------- JDM Powerplant installed, BPU coming very soon!
Nov 17, 2007 - 5:56 AM |
Enthusiast Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) |
Dont use this spacers, I got 2 pair on b4, the wheels was poking out quite noticable. Then a cop gave me a yellow sticker (car defects) which required me to take my car over the pit...and so I did, only they found more problem with the engine. It was leaking oil. I got fed up and started my 3swap instead of fixing the engine...
-------------------- 98% completion --- aaRon |
Nov 17, 2007 - 6:09 AM |
disregard those tacky comments; if you never take off your rims, other people will never know you have spacers.
A couple reason why not to get them are more unnessary parts which also mean more things to go wrong. If they are not made perfectly or installed correctly you will get vibration of the wheel and all sorts of nasty stuff. Just imagine if you installed your rims a hair off center, it would be fine and you would not notice. But when spacers come into the situation: when you install the spacers an hair off center then the rims are also installed a hair off center. This will cause twice the amount of error allowed in the wheel, causing unnessary vibration and ulimitly leading to spacer failure. A couple things you MUST do are 1) apply loctite to all the perminate lugs. 2) tighten down properly with a torque wrench 3) check on the spacers every 10, 50, 100 miles to make sure nothing has worked its way lose. Recomended things to do are to get new harden steel studs and tighten them down properly with loctite. Alot of people over tighten them and strip them out and then blaming the spacers. |
Nov 17, 2007 - 4:37 PM |
i guess you guys are right. More movable parts, more problems. I will wait and keep oem for now. I was liking to put some camry wheels, oem. I dont have much taste for aftermarket. I will keep searching for other rims...
Nov 17, 2007 - 7:08 PM |
Enthusiast Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
im running them on my car and am having no issues with them. They push the wheels and sit right flush with the fenders. I bought rims on ebay, they were advertised as 5x100 even thhe wheel was stamped 5x100 but with my luck were 5x114.3. i didnt wanna get rid of them. So i got adaptors made. they work perfectly. I saw a guy with a luxus IS at meet earlier this year and he said hes had them for 2 years now with no issues. I also saw a magazine article with the HKS time attack evo that is running the same style spacer as well. here in this picture its annodized blue. (original website http://www.supraforums.com/forum/showthread.php?p=5587743 ) and also before people start mistaking the adaptor as part of the rotor, its not. IF it were part of the rotor, then there would only be 5 holes for the wheel studs to poke though. But notice how there are 10 total, 5 flushed into the holes (for the adaptor) and 5 studs for the wheel to bolt on to. If this car could put down all that horse power and not hurt anything, you should be able to do so as well.
This post has been edited by eggman40: Nov 17, 2007 - 7:08 PM |
Nov 17, 2007 - 9:57 PM |
There are plenty of factory wheels that are 5x100
Matrix, tC, Celica GTS and GT, and Corolla 03+ I personally love the look of the GTS wheels on a 6GC, the tC wheels are so-so.. Looked too big imo especially without a drop. |
Nov 17, 2007 - 11:48 PM |
eggman i dig ur Endless calipers...they look mad.
How much did it cost ya? -------------------- 98% completion --- aaRon |
Nov 18, 2007 - 8:56 PM |
QUOTE(lubu @ Nov 17, 2007 - 8:48 PM) [snapback]615191[/snapback] eggman i dig ur Endless calipers...they look mad. How much did it cost ya? lol yea wish they were mine. Those are on the evo's brakes. Very nice looking. |
Lo-Fi Version | Time is now: December 12th, 2024 - 5:45 AM |
