> looking for some low weight, high surface area tires, 3sgte traction issues solved by increased tire mass?
post Nov 16, 2007 - 5:06 PM
boosted95
Joined Apr 19, '07
From Dayton, Ohio
im looking for a low weight, high tire mass set of wheels. thinking no bigger that 16s, but i want atleast an 8in width...
there a daydream i had today to aid in the traction issue the 3sgte swap incounters
poopra sellout... 88targa, 50trim ct, 383lsd, and shreadin tires like its my job!!!
QUOTE (RUNNIN-LOW @ Feb 17, 2009 - 1:53 PM) *
buying a rusty car is like dating a girl with a bush! if u like it like that go for it.. :D if u can repair and make it look better then its all the better for u!...
post Nov 16, 2007 - 7:55 PM
phonex98
Joined Mar 25, '06
im confused.... on earth, mass == weight.... so are you looking for heavy tires or lights ? i THINK you want light tires, large surface/contact area ?
----- '94 ST hatch --- Yellow -----
post Nov 16, 2007 - 8:46 PM
azian_advanced
Joined Apr 18, '05
From Calgary
i think he means low weight rims that are wide to be able to put wider thicker tires (more tire mass).
post Nov 16, 2007 - 10:10 PM
jdg371
Joined Jun 14, '05
I have a few suggestions.
245/45/16 Yokohoma AVS ES100 [requires 7.5-9in wheel]
your choice of wheels, its hard finding 16x8 and a good offset..
I would really suggest a set of 245/40/17 [Potenza RE-01R]
On 17x8 5Zigen FN01RC
The wheels are 16-17 LB a piece and those tires are sticky hell.
post Nov 17, 2007 - 12:11 AM
boosted95
Joined Apr 19, '07
From Dayton, Ohio
QUOTE(phonex98 @ Nov 17, 2007 - 12:55 AM) [snapback]614919[/snapback]
thats exactly what i wanted to say...
its a bad idea to try and post something in a hurry before work* i didnt take enough time to read what i wrote, sorry
i wanted to find the lightest weight set of rims, that would fit very wide tires. almost like a deepdish*
post Nov 17, 2007 - 10:56 AM
boosted95
Joined Apr 19, '07
From Dayton, Ohio
anything wider than the 5zigen? im looking for brands to lookup* drop all the names you know
post Nov 17, 2007 - 10:05 PM
jdg371
Joined Jun 14, '05
Its easier to find wider, but wider that will fit?
Something a little wider.. no clue about price..
Work XD9 17x8.5 +32 Offset.
post Nov 20, 2007 - 1:14 PM
jcbass7
Joined Apr 20, '06
From Florida
are you going to roll your fenders? i have 17x8 TSW's with a 35 offset and had to roll mine
post Nov 20, 2007 - 9:39 PM
jdg371
Joined Jun 14, '05
QUOTE(jcbass7 @ Nov 20, 2007 - 1:14 PM) [snapback]615944[/snapback]
What size tires are you using?
Lo-Fi Version Time is now: January 10th, 2025 - 1:31 AM
