> Best transmission fluid?
post Nov 16, 2007 - 7:37 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
I'd like to replace the transmission fluid in my car, and I've heard that synchromesh is very good for the Celica's transmission, plus it will get rid of any grinds (which I have a 3rd gear grind). Other then that, any other suggestions to what I can use?
BTW, is there any other way to fill up the transmission besides filling it in the side hole?
-Matt
post Nov 17, 2007 - 7:47 PM
ecaddiction
Joined Feb 27, '07
From Jacksonville
I used syncromesh. I didn't notice a difference, but mine's smooth. I'd say go for it.
And no, that side plug is the only way.
1997 Limited Edition Vert (((SOLD)))
post Nov 17, 2007 - 8:03 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
to be correct the stuff you put in the manual transmission is actually called gear oil. transmission fluid is the stuff that goes into the automatic tranny's.
The side plug is the only way. Its not like its hard, its like changing your oil. Just make sure you get the pump to pump the gear oil into your tranny, instead off having one of those bottles with the nose on them and you have to squirt from the bottle. IMO it works like crap.
94 Celica gt white (sold)
post Dec 6, 2007 - 12:37 AM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Sorry to bump an old thread, but I'd like to change my transmission fluid soon. Once the fluid is all drained, and if I don't have a pump, could I just pour each bottle into the transmission through the nozzle?
And it's about 3.5 quarts, right?
post Dec 6, 2007 - 3:05 AM
azian_advanced
Joined Apr 18, '05
From Calgary
you won't have enough room if you're pouring it straight from the bottle (at least i didn't).. i used a funnel that has a flexible hose to the end of it.
and it's 2.6 quarts for a refill btw
This post has been edited by azian_advanced: Dec 6, 2007 - 3:06 AM
post Dec 6, 2007 - 3:39 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE(azian_advanced @ Dec 5, 2007 - 10:05 PM) [snapback]620144[/snapback]
reallly???? mines was 3.75qts. oh and on another note........make sure the axle and tranny seals are perfect........cuz i just spent $45 on synchroMax made by royal purple........now its leaking from my axles...........sucks ballz
post Dec 6, 2007 - 9:22 AM
azian_advanced
Joined Apr 18, '05
From Calgary
yeah, you're probably right, i got the info for an AT, not MT. my bad
anyway, it should show the fluid capacity near the end of the handbook.
post Dec 8, 2007 - 2:35 AM
pasqual
Joined Nov 4, '06
From POLAND
What oil use for gearbox with LSD (S54+LSD)
TRD recommended some special oil :TRD LSD oil FF
Anyone have experiences ???
BEAMS swaped .......
post Dec 8, 2007 - 3:53 AM
Kadett
Joined Mar 17, '05
From The Netherlands
QUOTE(pasqual @ Dec 8, 2007 - 8:35 AM) [snapback]620849[/snapback]
TRD sells a LSD for the S54 tranny??
post Dec 8, 2007 - 4:19 PM
pasqual
Joined Nov 4, '06
From POLAND
QUOTE(pasqual @ Dec 8, 2007 - 8:35 AM) *
Yes ...
I have 3s-ge BEAMS .. but you can install
LSD in any S54 ....
post Dec 11, 2007 - 11:39 PM
dabazied
Joined Jun 10, '07
From Riverside, CA
just fyi, it's 2.6 on flat ground, if it's on jackstands it won't start leaking out until about 3.25 qts, just from my recent experience
She's Alive...... Again!!!
Sweet Jesus.
You rang?
Sorry, wrong number. :laugh:
Lo-Fi Version Time is now: January 9th, 2025 - 11:23 PM
