6 Pages V   1 2 3 > »
> !!5sfte!!, the second coming!
post Nov 17, 2007 - 3:13 PM
6strngs
Joined May 12, '06
From Wilmington, NC
yep, you heard me. I'm coming back to the 5sfte community. Doing things a little different this time around, here's what I can remember so far that I'm doing differently:
Genuine HKS BOV, the new 2007 design
Got my injectors cleaned and flow tested at witchhunter. They were is poor condition before and are great now!
Going with a SAFCII instead of a neo. I got it for about $75 cheaper, and it measures knock. I was gonna get a greddy emanage ultimate, but I don't have a laptop to tune it with and it just looked too complicated for me to figure out how to tune it by myself, so maybe I'll upgrade later.
Got a custom stailness braided oil feed and drain line kit made specifically for my 5sfte. I just gotta weld a fitting onto my oil pan but I'm having a hard time finding someone willing to do it.
I'm fixing my radiator fan which was broken before. the motor fell out of the blade cause it was hooked up wrong
I'm using a regular sized radiator instead of the koyo, for a little more engine bay room
I'm relocating the battery to the trunk
and I'm cutting my IC piping down a lot for a cleaner install, might even paint them like LewFX
that's all I can think of right now, pictures to come. hope to be running by the end of the week smile.gif after 6 months of down time!
post Nov 17, 2007 - 7:54 PM
ecaddiction
Joined Feb 27, '07
From Jacksonville
Pics when you get done!! Glad you stuck with it after all your frustration.
1997 Limited Edition Vert (((SOLD)))
post Nov 17, 2007 - 8:00 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Forget the pics, get some vids with the 5sfte in action bro. If not pics will do just fine.
I think cutting down the charge piping will make your engine bay hella clean. The set up you have in your profile, looks like you rushed a little with the piping. Or just lazy lol. GL with the set-up though.
94 Celica gt white (sold)
post Nov 17, 2007 - 8:09 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(bccentaur3 @ Nov 17, 2007 - 5:00 PM) [snapback]615138[/snapback]
don't have a video camera, but I'll see if I can borrow one.
as for the intake piping, it was more just because I was anxious to get it running, and it was intended to be temporary until I had time to cut it. but I only got to drive the car about 100 miles with the turbo on and any spare time I had was spent in hunting down oil leaks...
post Nov 17, 2007 - 8:13 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
woot.gif for VIDS. I know what you mean about being anxious man. Well once the oil leaks get taken care of, that ride is going to be sick.
post Nov 17, 2007 - 8:56 PM
1bwilson
Joined Aug 30, '02
From Maryland
Welcome back to team 5sfte!
Member of Team 5sfTe
post Nov 17, 2007 - 10:16 PM
6strngs
Joined May 12, '06
From Wilmington, NC
just finished installing the fuel pump, and I took a couple pic of my oil line kit for you. here's the flange that bolts onto the turbo:
here's the lines:
here they are threaded into the turbo
pic of the oil feed line (also note I turned my radiator hose around so it doesn't touch the turbo anymore smile.gif
and the oil drain line. Yes, I will be cleaning that area of the block up a bit before bolting everything on. it got a little dirty from oil that was leaking from my filter relocator kt and coolant that was leaking from an oil cooler hose. both those leaks will be taken car of though.
these kits should be available to anyone that wants one. Just contact Aaron at RabidChimp.com (this website makes a kit like this for 7mgte supras, I originally only asked to buy the flange to bolt onto my CT-26, but he wanted to make the full kit, so he did) However, I wouldn't order one yet, I think my oil drain line may be too short, I have to wait until I get my oil pan back on monday because I found somebody to weld it, but they can't get it done until monday.
that's all for now, I may work on it a little more later tonight. I still have to:
Install oil pan
Finish fixing radiator fan
connect remaining few connectors of my wiring harness
Install oil filter relocation kit
Install turbo
Install turbo oil lines
Install and cut IC piping
Install SAFCII
Install gauges
and relocate the battery (after I buy one... lol)
post Nov 17, 2007 - 11:02 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
So what was up with your other oil filter relocation kit? Like why was it leaking?
post Nov 17, 2007 - 11:08 PM
6strngs
Joined May 12, '06
From Wilmington, NC
cause I installed it wrong and the rubber O-ring wasn't exaclty where it was supposed to be. 100% my own fault. the canton racing filter adaptor and stainless braided lines is the only way to go for the oil filter relocation.
post Nov 17, 2007 - 11:09 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
you don't have to go stainless do you?
post Nov 18, 2007 - 12:46 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(bccentaur3 @ Nov 17, 2007 - 8:09 PM) [snapback]615183[/snapback]
technically no, but I thought I could get away with rubber hoses too and I regret it. You'll burn through them eventually due to how close they are to the downpipe. might as well just buy stainless to begin with and save yourself the trouble of buying things twice like I did. (actually... this is the third time buying them... I sold my other kit lol)
This post has been edited by 6strngs: Nov 18, 2007 - 12:47 AM
post Nov 18, 2007 - 12:48 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
LOL. You know what they say. 3rd times the charm.
post Nov 19, 2007 - 1:37 AM
6strngs
Joined May 12, '06
From Wilmington, NC
went to a pick'n'pull today and was surprised to see a 6th gen celica there! it was an 94 ST in the same color as my car. but almost everything had already been stripped from the car. all the interior pieces were gone except the steering wheel and dash board, the engine was gone but it still had a transmission (I think it was manual, but I'm not sure). I got what I wanted from it though, a radiator fan shroud and fan blade! smile.gif also got me a couple different oil dipsticks from 4th gen celica 3sfe's and one from a 5sfe from a 5th gen. I broke my dipstick while trying to get it out and haven't had a way to check my oil level since. but the reason why it broke was because it hit my downpipe and there is no way to pull it out and get it back in while the downpipe is still in place. I'm wondering if other people with 5sfte's have this problem or if it's just me? if so, what have you done to fix it?
I also took a look at a buddy's (Cali_Jeff) battery relocation set-up and I have a good idea how I'm going to do mine now, I just can't decide between running the wires under the car or under the door sill and behind the plastics.
and one last thing, I tried figuring out how I was going to cut down my IC piping and as I was poking around, I came up with a different method of routing it all together. I took a pic of the mock-up to give a general idea. I need to cut up a bunch of the piping, but this'll give the general idea. what do you think?
post Nov 19, 2007 - 1:40 AM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
when i saw pics of presure2 and shin's car, they had bent the entire line for the oil dipstick so that it faces a direction that you can get @ it
06 Civic EX
My For Sale Thread
post Nov 19, 2007 - 2:03 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(elvasoshexai @ Nov 18, 2007 - 10:40 PM) [snapback]615552[/snapback]
you mean bend the tube that the dispstick feeds into? should I just start smacking it with a rubber mallet? lol
post Nov 19, 2007 - 3:06 AM
6strngs
Joined May 12, '06
From Wilmington, NC
you asked for it, you got it! I just found I can upload videos from my cell-phone onto youtube (couldn't do this with my old phone). So, though the quality will be crappy at best, I can still have videos for you! here's a quick one of my IC piping:
http://youtube.com/watch?v=Twhr_dyigSM
and a picture of my fixed radiator fan for good measure.
This post has been edited by 6strngs: Nov 19, 2007 - 3:16 AM
post Nov 19, 2007 - 6:33 AM
what size is that return line?
post Nov 19, 2007 - 3:20 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Weird bends and angles, but hey it works.
post Nov 19, 2007 - 5:36 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(bccentaur3 @ Nov 19, 2007 - 12:20 PM) [snapback]615688[/snapback]
that was just a test fit, it won't look that wierd when it's finished.
Manny, the return line is -10AN and the feed line is -4AN.
post Nov 19, 2007 - 5:55 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
from my tuner guy, he said t-clamps suck...theres another product out there for half the price of a tclamp... it surrounds the pipe and clamps unless t-clamps one way tightening
6 Pages V   1 2 3 > »
Lo-Fi Version Time is now: November 28th, 2024 - 1:01 PM
