lack of heat st202 |
Nov 20, 2007 - 3:54 PM |
Enthusiast Joined May 28, '07 From eastbourne Currently Offline Reputation: 0 (0%) |
iv`e got cold air blowing from the a/c but when the temps turned up the air is only luke warm.
i`ve done a search or 2 and been told there could be air in the system or the thermostat could be faulty can anyone give me some detailed tips on how to flush the system out and start afresh and where the thermostat is again some details on removing this cheers |
Nov 20, 2007 - 7:01 PM |
there's a few threads on how to flush your radiator...
it's pretty simple. basically when you do it, be sure to have your hvac control dial set to hot and (if you can) jack up the rear of the car so it's inclined forward.. the drain plug is on the lower passenger side behind the radiator (a white plug) that comes off with a simple twist. the thermostat is inside the metal neck part of the passenger-side radiator hose coming into the block. there's two bolts holding it down.. but to gain access to it, you'll need to remove the alternator and loosen/remove the AC compressor in order to reach the bottom of the two bolts (if you have AC). after putting everything back together, make sure you bleed the system. i use a funnel (below) to bleed the system: it basically ensures that coolant is always topped off.. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Nov 20, 2007 - 7:08 PM |
squeezing the radiator hose a few times also helps the bubbles escape, but make sure the car isn't jacked up in the back during the bleeding process.
don't forget to fill up the overflow bottle about a quarter to half way.. as it warms up, the coolant will expand and dump some in the overflow bottle.. take note, once the bottle is filled, it will come out from a little overflow hole at the top of the neck and (possibly) make a bit of a mess. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Nov 21, 2007 - 1:26 AM |
Check the black cable that goes from the climate control unit through the firewall to the heater control valve. Make sure it didn't come unclipped from its holder under the dash. If it did the valve will not open when the temperature control knob is moved and will prevent the heater core from getting warm.
-------------------- Project ST204.5 99.88946% complete... |
Nov 21, 2007 - 1:33 AM |
this is the cable WannabeGT4 is referring to, fyi:
Nov 21, 2007 - 1:46 AM |
Thanks Azian. I'm too lazy to post illustrations.
Enthusiast Joined Nov 17, '07 Currently Offline Reputation: 0 (0%) |
QUOTE(WannabeGT4 @ Nov 21, 2007 - 1:26 AM) [snapback]616188[/snapback] Check the black cable that goes from the climate control unit through the firewall to the heater control valve. Make sure it didn't come unclipped from its holder under the dash. If it did the valve will not open when the temperature control knob is moved and will prevent the heater core from getting warm. he should check the blue one... thats the one that controls the heat |
Nov 21, 2007 - 1:48 AM |
Blue controls the air mixer door. Black controls the heater core valve. Both should be checked actually.
Nov 21, 2007 - 1:50 AM |
agreed wannabe
Nov 21, 2007 - 1:56 PM |
Enthusiast Joined Feb 28, '07 Currently Offline Reputation: 1 (100%) |
QUOTE(azian_advanced @ Nov 20, 2007 - 4:01 PM) [snapback]616077[/snapback] there's a few threads on how to flush your radiator... it's pretty simple. basically when you do it, be sure to have your hvac control dial set to hot and (if you can) jack up the rear of the car so it's inclined forward.. the drain plug is on the lower passenger side behind the radiator (a white plug) that comes off with a simple twist. the thermostat is inside the metal neck part of the passenger-side radiator hose coming into the block. there's two bolts holding it down.. but to gain access to it, you'll need to remove the alternator and loosen/remove the AC compressor in order to reach the bottom of the two bolts (if you have AC). Azian u got one of these for the ST?id like the wiring diagram and what ever technical diagrams there are please,pm them to me plz.thanks,srry for the thread jack -------------------- BANNED. for life, you moron.
Nov 23, 2007 - 12:52 PM |
thanks for the helpfull replys guys, i`ll get my boyfriend to flush the radiator through at the weekend, but i`ll leave the thermostat to my mechanic
Nov 23, 2007 - 2:46 PM |
its not that hard^^^,drain the coolant,flush it out with water,add new coolant...
Nov 23, 2007 - 3:03 PM |
QUOTE iv`e got cold air blowing from the a/c but when the temps turned up the air is only luke warm. I remember reading here that someone here had the same problem, check your ground wire on the climate unit.. |
Nov 23, 2007 - 5:16 PM |
where would that be? it`ll give him something to do tomorrow |
Nov 23, 2007 - 5:48 PM |
http://www.6gc.net/forums/index.php?showtopic=53089
This post has been edited by Celicam8: Nov 23, 2007 - 5:48 PM |
Nov 23, 2007 - 6:40 PM |
thanks once again
Lo-Fi Version | Time is now: November 23rd, 2024 - 9:47 AM |
