3 Pages V  < 1 2 3
> Allen Key
post Nov 23, 2007 - 9:03 PM
Celicam8
Joined Nov 17, '07
I dont have endlinks yet... i had 5guage single stranded wire i used to attach it.. just wanted to make sure no noise....
and I almost broke my ratchet as i was finishing unscrewing, it started skipping, isnt busted yet... i used my tire iron to tighten the bolts... and i forgot that little ring the first time (one that goes under the nut that screws in the strut) and i removed the one on the passanger side because i thought it would be better... what a mistake... had to remove everything and remove the nuts (took about 30 min... melted the plastic on the ring, took clams and clamped a cloth thing to the strut so it stays and doesnt turn... anyways smile.gif done and looks nice
BTW... IM F**king tired!!!! =) it was fun though, and I think I learned a way to replace the boot breaks with roters. I'll try to get some breaks smile.gif
7th generation ones work... correct?
This post has been edited by Celicam8: Nov 23, 2007 - 9:48 PM
post Nov 27, 2007 - 10:29 PM
Celicam8
Joined Nov 17, '07
hey centaur i ordered the sway bar links smile.gif they will come in tomorrow or thurs smile.gif i cant wait
post Nov 28, 2007 - 11:33 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
DANG finally. Its taking such a long time. Well since thanksgiving was last week i guess it would take a while.
94 Celica gt white (sold)
post Nov 28, 2007 - 12:26 PM
Celicam8
Joined Nov 17, '07
post Nov 29, 2007 - 12:58 AM
Celicam8
Joined Nov 17, '07
btw, it seems like a stiffer ride than stock... then again my struts were shot.... is it stiffer or is it me... for example if i go over a bump if feel it more than i would normally... and how tight should the nuts that are holding the spring be... i tightened it till it wouldnt go anymore, seems like it should be more loose....
This post has been edited by Celicam8: Nov 29, 2007 - 12:58 AM
post Nov 29, 2007 - 1:13 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
you lowered the car too right?? if so then of course its supposed to be stiff.
post Nov 29, 2007 - 1:32 AM
Celicam8
Joined Nov 17, '07
yea, 1,5" but it seems... stiffer than should be.. i feel every bump, might be that i need a 4wheel alligment now, but... either way... to add to that my steering wheel is shaking in a weird way.. where its making noises.... i think its the alligment, but when im standing still its also happening...
post Nov 29, 2007 - 1:35 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
WHAT???? Your steering wheel is shaking at idle? what did you do?
post Nov 29, 2007 - 9:32 AM
Celicam8
Joined Nov 17, '07
i didn't do ****.... its weird... never done this before, but than again not much is different since been changed, and nothing was changed that would do that
post Nov 29, 2007 - 12:43 PM
Celicam8
Joined Nov 17, '07
I JUST GOT THE LINKS!!
wow, that was a quick install.... about 5 min each one tongue.gif fun
btw, i know it says 2:00 but i was back and forth talking to people... install itself was quick...
This post has been edited by Celicam8: Nov 29, 2007 - 2:02 PM
post Nov 29, 2007 - 6:26 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
So hows the celi riding now?
post Nov 29, 2007 - 6:43 PM
Celicam8
Joined Nov 17, '07
fu*king awsome... doesn't feel like a celica anymore. I need to get an alligment bad though, i took the car on a turn at about 45 and it started hopping tongue.gif then again i was going a little fast
but yea, those swaybar links are great i like them, made everything in the back stiff... next would be replace the swaybar and the arms that connect to the frame tongue.gif i wanna get full suspension done before putting new engine... and i need rear breakpads not boots...
post Nov 29, 2007 - 11:01 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Nice you have the right thought in mind. I am doing the same thing, but sucks because its going to snow soon and I dont have a heated garage.
post Nov 30, 2007 - 1:40 AM
Celicam8
Joined Nov 17, '07
same here, but im looking at the positive, its going to be better... btw dont do things like this in winter (i wont be either) you need to test your car and take it for a "drive" and winter isnt the safest time to do that smile.gif
3 Pages V  < 1 2 3
Lo-Fi Version Time is now: November 27th, 2024 - 3:57 PM
