Clutch squeak, mouse in my transmission? |
Nov 21, 2007 - 2:11 AM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
what do i have to do to stop it its annoying me
Nov 21, 2007 - 2:26 AM |
Enthusiast Joined Feb 28, '07 Currently Offline Reputation: 1 (100%) |
wait,when does it squeak?when u shift,at high rpms?cold weather,hot weather?
-------------------- BANNED. for life, you moron.
Nov 21, 2007 - 11:59 AM |
when I push the clutch pedal in, my dad & brother said to get in there with some greese (but putting too much, very bad)
Nov 21, 2007 - 1:42 PM |
how many miles on the clutch?
Nov 21, 2007 - 11:47 PM |
Enthusiast Joined Aug 19, '07 From Farmington, MI Currently Offline Reputation: 7 (100%) |
does it always continue to squeak when the clutch is being pushed in, if so then its ur clutch fork, and the only way to make that stop is dropping the trans
Nov 22, 2007 - 12:47 AM |
cars done 60,000km (as far as I know it hasn't been changed)
if its the clutch fork, what would have done that? -------------------- |
Nov 22, 2007 - 1:09 PM |
Enthusiast Joined Feb 27, '07 From Jacksonville Currently Offline Reputation: 0 (0%) |
Take a look at this if its not coming from the tranny area. http://mr2.com/TEXT/SqueakClutch.html
-------------------- 1997 Limited Edition Vert (((SOLD))) |
Nov 22, 2007 - 2:22 PM |
QUOTE(Rusty @ Nov 22, 2007 - 12:47 AM) [snapback]616487[/snapback] cars done 60,000km (as far as I know it hasn't been changed) if its the clutch fork, what would have done that? time, the grease does not last forever.... the eaisest way is to drop tranny, buy a clutch kit since you dont want to do that again, and grease everything you need to grease.. make sure its not something else before you end up doing something unnecessary. Try putting some mouse bait near the tranny. you can maybe catch that rodent... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Nov 22, 2007 - 3:37 PM |
^ lol
I've found where its coming from, the clutch ball joint(?) where it joins up with the fork not too sure as what to spray/greese it up with though This post has been edited by Rusty: Nov 22, 2007 - 3:37 PM -------------------- |
Nov 22, 2007 - 5:06 PM |
Enthusiast Joined May 7, '04 From Leeuwarden, Netherlands Currently Offline Reputation: 0 (0%) |
Apply some force on it with the engine turning, if the sound stops, or you start to hear it, then it might the pressurebearing.
Nov 22, 2007 - 11:11 PM |
QUOTE(Rusty @ Nov 22, 2007 - 3:37 PM) [snapback]616659[/snapback] ^ lol I've found where its coming from, the clutch ball joint(?) where it joins up with the fork not too sure as what to spray/greese it up with though do this. you can take off the slave clutch thing off. then if you have a dremel tool, whack the rust off the piston and the fork. Then apply high temp grease there. dont spray anyting since it only last for a while and might get inside the tranny. this is what i did when i changed my clutch. It does not squeak. it will last longer... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Nov 24, 2007 - 9:19 AM |
Enthusiast Joined Oct 4, '07 From Nova Scotia Currently Offline Reputation: 0 (0%) |
Both my Toyotas do this, if you pull that boot off you can see inside with a mirror and lube the part in question. It's kind of difficult and I've pretty much given up on keeping it lubed myself.
Lo-Fi Version | Time is now: November 26th, 2024 - 8:21 AM |
