Confirm Offset Clearance |
Nov 21, 2007 - 4:33 AM |
I am thinking of getting Black Racing Pro N1 Bronze Wheels and I wanted to make sure I maximize as much as I can with the offset. I have a drop of almost 2 in. Which would be best to have clearance without hitting the fender, suspension, or anything else. I've read the offset thread but that doesn't give me enough confidence. Thanks.
17x7.5 +48 17x7.5 +35 17x8 +38 -------------------- 94 Celica GT
Nov 22, 2007 - 12:38 PM |
17x7.5 +35 or 17x8 +38 will be fine.
-------------------- Project ST204.5 99.88946% complete... |
Nov 23, 2007 - 8:40 AM |
QUOTE(WannabeGT4 @ Nov 22, 2007 - 12:38 PM) [snapback]616602[/snapback] 17x7.5 +35 or 17x8 +38 will be fine. Based on your thread in the past, isn't 17x8 +38 too wide with a lowered car? Here is your old listing. It says 17x8 +40 is the recommended. Would I be hitting anything or rubbing? Ideal Offset in Relation to Wheel Width (lower ride height): Width - Offset 7.0"-----36mm with 10mm spacer (effectively 26mm) * 7.5"-----33mm 8.0"-----40mm 8.5"-----46mm * 9.0"-----53mm (probably too wide no matter what offset) This post has been edited by trdproven: Nov 23, 2007 - 8:41 AM -------------------- 94 Celica GT
Nov 23, 2007 - 3:30 PM |
QUOTE(trdproven @ Nov 23, 2007 - 7:40 AM) [snapback]616875[/snapback] QUOTE(WannabeGT4 @ Nov 22, 2007 - 12:38 PM) [snapback]616602[/snapback] 17x7.5 +35 or 17x8 +38 will be fine. Based on your thread in the past, isn't 17x8 +38 too wide with a lowered car? Here is your old listing. It says 17x8 +40 is the recommended. Would I be hitting anything or rubbing? Ideal Offset in Relation to Wheel Width (lower ride height): Width - Offset 7.0"-----36mm with 10mm spacer (effectively 26mm) * 7.5"-----33mm 8.0"-----40mm 8.5"-----46mm * 9.0"-----53mm (probably too wide no matter what offset) No. A larger offset on a rim of the same width will cause it to be set further inside the wheel well... 2mm is hardly going to make a difference anyway. -------------------- Project ST204.5 99.88946% complete... |
Nov 23, 2007 - 3:43 PM |
I see, so I won't hit the fender then on a bump?
Nov 23, 2007 - 3:56 PM |
QUOTE(trdproven @ Nov 23, 2007 - 2:43 PM) [snapback]616942[/snapback] I see, so I won't hit the fender then on a bump? You should be fine. I used the measurements from two other peoples cars to get those numbers so I don't think there should be any problems. This post has been edited by WannabeGT4: Mar 21, 2008 - 1:58 AM -------------------- Project ST204.5 99.88946% complete... |
Nov 24, 2007 - 10:16 PM |
Thanks, this helps a lot, I am tired of 7" wheels.
Lo-Fi Version | Time is now: November 28th, 2024 - 10:42 AM |
