> 3s-gte engine swap, how much and what do i need to do to my car
post Nov 24, 2007 - 9:12 AM
lime97celi
Joined Nov 23, '07
From massachussets
i have a stock 97 st 1.8 and i want a 3s-gte engine how much do they cost and what else do i have to do to make it fit in my car basically how much would the whole project cost
post Nov 24, 2007 - 12:37 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
since you have an ST you'll need the GT motor mounts. You'll want to buy a front clip, unless you can find a complete motor with the parts that usually come in the a clip. You'll have to get your wiring harness done to work with the 3sgte. You'll also need a tranny because your ST tranny won't work. If you've read the stickies cost vary from 3000 to 4000 depending on resources and whos doing the swap.
94 Celica gt white (sold)
post Nov 24, 2007 - 10:46 PM
lime97celi
Joined Nov 23, '07
From massachussets
QUOTE(bccentaur3 @ Nov 24, 2007 - 12:37 PM) [snapback]617137[/snapback]
my car is a front wheel drive manual car would i have to get a front wheel drive transmission ?or can i just use a awd manual transmission
post Nov 24, 2007 - 11:07 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
with the awd tranny that comes with the 3sgte from the gtfours I'm not sure but I think you will have to do some modification to get it to work. You can go out and get the tranny off of a regular GT and it will bolt up. Did you read the stickies yet? It will help you tons.
post Nov 25, 2007 - 7:57 AM
lime97celi
Joined Nov 23, '07
From massachussets
what r stickies sorry =(
post Nov 27, 2007 - 1:16 PM
jcbass7
Joined Apr 20, '06
From Florida
just buy a manual tranny from a celi GT and axles and it will mount right to the 3s. what part of mass are you from? im north of boston.
post Nov 27, 2007 - 10:07 PM
lime97celi
Joined Nov 23, '07
From massachussets
i live in worcester so if i get the gt transmission it will bolt onto the 3sgte and that would make it front wheel drive?
post Nov 28, 2007 - 12:57 AM
lime97celi
Joined Nov 23, '07
From massachussets
does it matter what year the gt transmission is as long as its a 6th gen transmission?
Lo-Fi Version Time is now: November 27th, 2024 - 11:08 AM
