7afte |
7afte |
Nov 29, 2007 - 9:14 PM |
Enthusiast Joined Oct 27, '05 Currently Offline Reputation: 0 (0%) |
pabel89,
do a search and i can assure you need days to finish all the reading and find out each diff setup and the problem that they faced before. Its how determine you are to find out more info. I must admit i did dig back all the existing FTE owners, PM thm for more info like what is their setup and what is the power achievement. At least i think this is the homework i should do.... |
Nov 29, 2007 - 11:21 PM |
QUOTE(pabel89 @ Nov 24, 2007 - 7:31 PM) [snapback]617214[/snapback] thts to expensive its like $250 im trying to turbocharge it under $1500. well hurley97 said the best injectors for the 7A is the high impendance. the stock injectors are top feed high impedance. if you get anything other than the same format you need to wire in resistors and what not and/or get another fuel rail. top feed and side feed fuel rails are completely different. that being said... QUOTE(thespacepanda @ Nov 24, 2007 - 7:27 PM) [snapback]617212[/snapback] Question: I've heard that you can pull the injectors out of a mk3 supra's 7M-GE and put them into a 3S-GTE because of the same head. Is there an engine with better fuel injectors that use the F series head that can be put into the 7A? there are 2 kinds of injectors that come out of a 7M-GE Supra. both are top feed but the yellow top are low impedance, while the lime green tops are high impedance. [if I am not mistaken] the 3S-GTE uses side feed injectors. it has been said you can use the injectors from a Ford Probe turbo or Mazda Miata turbo. -------------------- |
Nov 29, 2007 - 11:24 PM |
also... there is a very comprehensive list of parts in my thread.
you can remove or add what you want but the basic things are there. that list was before I added the Wideband O2 sensor -------------------- |
Nov 30, 2007 - 2:12 PM |
Enthusiast Joined Sep 28, '07 From new jersey Currently Offline Reputation: 1 (100%) |
after all these parts and all this stuff u guys messaged me im having lil doubts of even turbocharging my 7afe and i was about to quit im gonna see what im a do cuz its deff gonna take me a while to figure out and i dnt wanna blow my engine thanxs alot thoe
Nov 30, 2007 - 2:38 PM |
lol "make me a list"
Dec 3, 2007 - 5:45 PM |
ok so this what i got so far for my turbo setup
t3/t4 turbo wastegates, gaskets turbo header oil feed line BOV turbo pressure sensor e manage unit NGK spark plugs mazda mx-6 turbo injectors intercooler 28x5.5x2.5 intercooler piping supra TT 255lph walbro fuel pump...do i need any custom work to get this in my car?? sard fuel pressure regulator fuel gauge custom downpipe oil return line boost controller EGT gauge boost gauge fuel line |
Dec 3, 2007 - 10:00 PM |
Enthusiast Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
You need to read the existing 7A-FTE threads, man. You are asking way too many basic questions that are already answered. All those PMs you sent me have been answered already in detail.. I've been nice to answer them, but you need to do a bit more work by yourself, bro. If you take a week or two to read all the threads, you will understand everything and you will not have to ask any more questions, leaving you time to concentrate on making your mind on parts and installing them.
Dec 4, 2007 - 5:37 AM |
pabel89,
whn you said "this what i got so far for my turbo setup" meaning you have already bought and got the item with you? or what you've got in your list? |
Dec 4, 2007 - 2:37 PM |
yea i kno but im only 17 u guys got more experince with the 7afte and i dnt wanna blow my engine up so thts why im asking so many question i wanna 110% sure of what im about to do....
and yea those are the parts i already have with me except for the turbo pressure sensor and the e manage. |
Dec 4, 2007 - 8:09 PM |
having all the parts doesnt help or means you will not blow your engine. getting your knowledge or foundation right is the main key that u will not blow your engine.
Dec 6, 2007 - 7:27 PM |
where can i get an oil return line for my turbo i have the oil feed line.
Dec 6, 2007 - 11:47 PM |
Enthusiast Joined Feb 27, '07 From cape coral/ft myers florida Currently Offline Reputation: 7 (100%) |
QUOTE(pabel89 @ Dec 6, 2007 - 7:27 PM) [snapback]620341[/snapback] where can i get an oil return line for my turbo i have the oil feed line. jgstools.com thats where i got mine i just installed on my car -------------------- BOOST GETS YOU LAID!!!! |
Lo-Fi Version | Time is now: November 28th, 2024 - 2:02 PM |
