> 5 Speed Install Problems - 5SFE, Won't Slide In
post Nov 28, 2007 - 7:30 AM
Shytheed_Dumas
Joined Nov 13, '07
From Louisville, KY
So we managed to pull the old tranny out, installed a new release bearing, lubed the splines, installed the clutch with the alignment tool and torqued the pressure plate to spec. Using a 3 ton floor jack and an extra set of hands we have lifted the tranny into rough position with the rear motor mount set into the bracket, but unconnected. The lower cross member is hanging in front with the nuts just started on the rear. The mount near the battery is off for now.
First issue is that the rear mount causes the tranny to twist a little. We can get it lined up to near perfect with a pry bar, but I don't like any binding if I can help it. Once aligned we have no problem getting the shaft to touch up with the clutch - in fact I know we have engaged the splines more or less, because turning the flywheel causes everything in the transmission to turn.
But it stops dead at this point, and the closest we have come to pusing it home is with about 1-1.5" to go all the way around the bell housing - defintely before hitting the guide pins, so that's not the hangup. When it stops going in, the transmission seems to pivot as though it is balancing on the shaft. We have quadruple checked, and there is nothing jammed between the housing and motor.
So what could I be getting stuck on?! My only guess is that I didn't do as good a job as I thought with the alignment tool? I'm out of town on business and planning to pull the plate/clutch and try again this weekend or early next week, but if there are ANY other ideas or suggestions, I'm all ears.
This post has been edited by Shytheed_Dumas: Nov 28, 2007 - 7:54 AM
post Nov 28, 2007 - 4:52 PM
take the mounts out.
you dont want them in the way.
for me, the best thing ive found to do is to jack the car up nice and high, lay on my back under the car, and basicly bench press the tranny into place.
a bit of wiggling, and it usually pops on enough for me to get a couple bolts started.
i usually cant get the tranny 100% locked on without using the bolts to tighten it all the way.
there is usually 1/4 - 1/2 " gap left then i lock it the rest of the way down using the bolts.
post Nov 28, 2007 - 6:16 PM
Shytheed_Dumas
Joined Nov 13, '07
From Louisville, KY
Thanks for the reply!
I hope I don't sound stupid here, but how do you get the rear mount in after the fact? It's tight back there. Also, I assume you mean pull the mount out of the bracket attached to the tranny? Or do you mean leave the single long bolt in and take it off at the bracket? Just need a little clarification. smile.gif
What do you make of the possibility that I didn't get the clutch completely aligned? Anything to that?
post Nov 28, 2007 - 6:50 PM
use the alignment tool again. Make sure the disk is on properly and you should be good to go.
Keep the rear mount bracket on but take the mount out. After the tranny is bolted back on, you need to get the mount with the crossmember and work them both into place, it's tough to get it back in, but it can be done, you just need to wiggle and work it just right. Once you get the mount in place, you'll need to lift the tranny to get the bolt through. Sometimes if you bolt the front mount in it will be easier to get the rear bolt through.
post Nov 28, 2007 - 6:52 PM
QUOTE(Shytheed_Dumas @ Nov 28, 2007 - 6:16 PM) [snapback]617866[/snapback]
1. leave the brackets on the tranny.
2. The tranny might not go in all the way, because if you look careful on the edge of the engine there is a bolt, that needs to match with the tranny hole. its a guide. Its a pita to find it. but once you do, it will snap in. also it needs to go in at the perfect angle, and you have to give it a little force.
3. once you put in the tranny and torqued it to specs. Put the drivers side engine mount and torque it. with a jack under the front mount lift the engine a couple of inches, not to much. tis will give space for you to play with the crossbar and the rear mount will go in. its not bad once you done it once.
gl
post Nov 29, 2007 - 7:59 AM
Shytheed_Dumas
Joined Nov 13, '07
From Louisville, KY
Just the answers I was looking for. This should be plenty to go on, and a great set of descriptions. Next post early next week should be - JOB DONE!!! Be looking for it. wink.gif
This post has been edited by Shytheed_Dumas: Nov 29, 2007 - 7:59 AM
post Dec 7, 2007 - 9:46 AM
Shytheed_Dumas
Joined Nov 13, '07
From Louisville, KY
Finally figured out that it was just a matter of technique, and that the shaft was getting hung up on the disc. After playing with the old transmission and clutch plate we figured out how the transmission had to move to take the splines and six attempts later it slid right in. Leaving the rear motor mount off was definitely the right thing to do. So THANK YOU for the tips! I still have to fill the tranny with fluid and tie up a couple of loose ends like battery, air filter, etc., and then I'm ready to give it a go. Fingers are crossed!
Any solid recommendations on brand of gear oil? Also, what is the recommended weight? I forgot my books at home and want to pick everything up on the way home. Never mind - 75W-90 and RP seems to be preferred here. 3.75 quarts is refill capacity on the 5 speed, right?
This post has been edited by Shytheed_Dumas: Dec 7, 2007 - 9:53 AM
post Dec 7, 2007 - 10:19 AM
QUOTE(Shytheed_Dumas @ Dec 7, 2007 - 9:46 AM) [snapback]620559[/snapback]
Some people use syncromesh here from penzzoil, difficult to get, have to order it. i think its 2.7 qts. Usually while you are filling, do it until it tops out and starts leaking.... GL
It took me a week to do this job too!
Lo-Fi Version Time is now: November 26th, 2024 - 1:25 PM
