![]() Enthusiast ![]() ![]() Joined Oct 11, '06 From calgary Currently Offline Reputation: 5 (100%) ![]() |
If I were to buy this...
[url=4th gen 3sgte from ebay ]http://cgi.ebay.ca/JDM-3SGTE-TOYOTA-CELICA-94-4rd-Gen-Engine-manuel-swap_W0QQitemZ310002834829QQihZ021QQcategoryZ33615QQssPageNameZWDVWQQrdZ1QQcmdZViewItem[/url] US $1,900.00 * ENGINE * TRANSMISSION MT AWD * INTAKE MANIFOLD * EXHAUST MANIFOLD * COMPLETE WIRING * ECU * DISTRIBUTOR * INTERCOOLER * INJECTORS * FUEL RAIL * AC COMPRESSOR * POWER STEERING * ALTERNATOR * ETC Add to that from what I know since I have an Auto -GT motor mounts -shifter -shifter cables -Clutch pedal assembly I'm assuming the rest of the Manual conversion stuff like -Flywheel -Clutch Master cylinder -Slave cylinder -New clutch -Clutch metal fluid lines -Rubber clutch line -Flywheel bolts -Pressure plate bolts comes with the engine? |
![]() Enthusiast ![]() ![]() ![]() Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) ![]() |
firstly you cant use the awd gb, ull have to buy the fwd gb, celica s53&54 or one from an mr2 or camry.
if you have the 205 cut then ur in luck coz you can use most of them stuffs from it, if ur cut is an 185 then: the clutch mater cylinder will not fit ...for an 205 you'll still need to mod it to fit. slave cylinder usually comes with the gb, or you can search for one from a wrecker. clutch & brake wont fit. not sure abt the other parts, since most of them didnt fit..i didnt bother with them. btw you will the manual axels..the auto's are a tad shorter. This post has been edited by lubu: Nov 29, 2007 - 5:13 AM -------------------- ![]() 98% completion --- aaRon |
Lo-Fi Version | Time is now: February 18th, 2025 - 6:58 PM |
