> Rear Washer/Wiper, Help
post Dec 1, 2007 - 12:35 AM
CelicaST94
Joined Sep 23, '07
From Scranton,PA
OK.When I turn the rear washer knob thing the rear wiper don't move & the washer don't squirt. Fuse? Wiring?
post Dec 3, 2007 - 12:31 AM
burmeseboy
Joined Jul 5, '07
From 626
i wanna kno wats wrong 2 i have same problem *bump
post Dec 9, 2007 - 6:01 PM
CelicaST94
Joined Sep 23, '07
From Scranton,PA
bump
post Dec 10, 2007 - 12:02 AM
cjh4l22
Joined Oct 18, '06
From cincinnati
replace the pump at the bottom of the washer fluid reservoir. i did. fixed! smile.gif
post Dec 10, 2007 - 8:38 AM
trdproven
Joined Aug 2, '05
From Guam
what about motor, did you notice it in the past getting weaker or less mobile?
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Dec 10, 2007 - 12:39 PM
CelicaST94
Joined Sep 23, '07
From Scranton,PA
QUOTE(trdproven @ Dec 10, 2007 - 8:38 AM) [snapback]621387[/snapback]
When I got the car it didn't work.Not even the wiper blade itself.I'm not seeing how replacing the pump is going to fix the whole problem...
post Dec 14, 2007 - 3:47 AM
burmeseboy
Joined Jul 5, '07
From 626
i still got that problem my only works sometimes randomly.. O_O still duno y it dont work tho
post Dec 20, 2007 - 7:21 PM
CelicaST94
Joined Sep 23, '07
From Scranton,PA
bump,no on knows?!
post Dec 20, 2007 - 9:39 PM
azian_advanced
Joined Apr 18, '05
From Calgary
first thing you can do to check is to unplug the connectors leading to the wiper motor, turn on the rear wiper, and test the connector if any power is being supplied.
if there is power, then you might need to replace the motor.
post Dec 20, 2007 - 9:41 PM
CelicaST94
Joined Sep 23, '07
From Scranton,PA
QUOTE(azian_advanced @ Dec 20, 2007 - 9:39 PM) [snapback]624653[/snapback]
Will that fix both or only the wiper?
post Dec 21, 2007 - 1:30 AM
burmeseboy
Joined Jul 5, '07
From 626
where can i find this connectors leading to the wiper motor?
post Dec 28, 2007 - 2:10 AM
CelicaST94
Joined Sep 23, '07
From Scranton,PA
does anyone think it could be both the motor and pump? is there even a rear pump? everything works on the front.
post Dec 28, 2007 - 6:00 PM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
looking at the schematic there is only one pump. Based on the circuit it appears the motor changes direction for the front or back with a relay that is part of the pump.
First hold the switch to supply water for the rear window and listen for the pump. Mine usually take at least 10-15 secs before I get fluid in back.
You will need to pull the rear panel and check for power at the wiper motor. The pump and wiper motor get power from the same fuse. So if your fronts work the back should too.
post Jan 3, 2008 - 4:50 PM
CelicaST94
Joined Sep 23, '07
From Scranton,PA
Just tried but no go.not even noise. when I go to the top wash/wipe setting it only wipes...
post Jan 19, 2008 - 1:41 AM
CelicaST94
Joined Sep 23, '07
From Scranton,PA
QUOTE(CelicaST94 @ Jan 3, 2008 - 4:50 PM) [snapback]627885[/snapback]
Bump
post Jan 19, 2008 - 6:44 AM
stevest202
Joined Oct 28, '07
From epworth uk
it sounds like you have two problems one the motor itself as said you will have to strip back part of interior door trim to access wiper motor unplug connector and test for power if power is there you will require a motor if no power when switched its fuse /wire problem may be check fuses before you strip out
the washer jet is only one pump at the front located at the bottom of washer fluid bottle and is most likely a weak pump i replaced mine as front would work but not back hope this helps a bit and good luck sorting
post Jan 19, 2008 - 12:44 PM
CelicaST94
Joined Sep 23, '07
From Scranton,PA
is there something in the motor that knows is fluid is coming out? and where might the fuses be located cause i looked in the manual and couldnt a rear wiper or washer.
post Jan 19, 2008 - 3:30 PM
stevest202
Joined Oct 28, '07
From epworth uk
if you pull back fuse cover look on the cover itself theres a fuse list of size and what it does the itself dosnt know water is flowing its just on same power circuit
post Jan 19, 2008 - 4:13 PM
CelicaST94
Joined Sep 23, '07
From Scranton,PA
QUOTE(stevest202 @ Jan 19, 2008 - 3:30 PM) [snapback]632403[/snapback]
i uhh am not aware of any "back" fuse cover.only the 2 in the cockpit and 1 under the hood.
This post has been edited by CelicaST94: Jan 19, 2008 - 4:13 PM
post Jan 23, 2008 - 3:32 AM
GreenyST204
Joined Apr 11, '06
From Tasmania
Info for you reading
Wiper Doc
also got wiring diagram for Rear Wiper Washer but cant find a link on the net so email me if you want.
I got a question too.
Are their any pumps that will fit out of other toyota's because my rear washer se has broken off at the pump.
need to find a replacement.
Ok Gladys, lets play house, you be the door and I'll shut you.
Lo-Fi Version Time is now: November 23rd, 2024 - 12:39 AM
