what is the voltage out put of the Factory radio, Fixed my prb.. |
Dec 1, 2007 - 10:14 PM |
I have a factory unit, that i tapped into the rear speakers to add another amp for woofers. I know this is line output. What is the voltage? 1.
REason i ask, is because i have found a power amp, but i raise the gain level all the way, and my stock amp makes the speakers sound louder thant my sub woofs... should i use a pre amp in between? this sucks This post has been edited by njccmd2002: Dec 3, 2007 - 7:44 PM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Dec 1, 2007 - 10:21 PM |
Enthusiast Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) |
a good pre amp might clean up the signal a little but thats about it... its either the amp... whats the output? or in the wiring of the woofers.... an 8 ohm load to a small amp is not going to make any kinda power behind any woofers
-------------------- Breaking Axles...
Dec 2, 2007 - 7:58 AM |
you mean the woofers itself. Ill check the ohms.
the same system ive seen it behind a pioneer and the woofers kick ass with this jensen 600. Tapped into my radio its just like regular speakers..... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Dec 2, 2007 - 9:37 AM |
it has something to do with your amp and how well it handels the line level inputs.
Most amps do a terrible job converting high level signal inputs to clean sound. so you may have to get one of these: http://autoparts.pricegrabber.com/dress-up...ers/m/53280927/ |
Dec 2, 2007 - 11:33 AM |
QUOTE(Hanyo @ Dec 2, 2007 - 9:37 AM) [snapback]618950[/snapback] it has something to do with your amp and how well it handels the line level inputs. Most amps do a terrible job converting high level signal inputs to clean sound. so you may have to get one of these: http://autoparts.pricegrabber.com/dress-up...ers/m/53280927/ my radio is not high level output. its the one that uses the factory amp, which is line level. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Dec 3, 2007 - 1:41 AM |
where are you tapping into it at?? tap in at the rear speakers and it will be high level
Dec 3, 2007 - 7:42 PM |
QUOTE(pittfirefighter @ Dec 3, 2007 - 1:41 AM) [snapback]619158[/snapback] where are you tapping into it at?? tap in at the rear speakers and it will be high level I fixed it. A while ago I installed a OEM Double din 6 disc changer from a camry. Well i had to do a custom harness. Since the deck is a 20 pin, and our decks are 15 pin (amplified systems). Thats where i tapped the wires, they come directly from the radio. Therefore they are not high level output. Now what i did, i had to go old skool, i had a Clarion 90EQ, that has outputs for woofers, so i decided to give it a try. Conected the EQ before the amp and bridged the channels. Now i have to soundproof my trunk because my car now rumbles. thanks to everybody. pic This post has been edited by njccmd2002: Dec 3, 2007 - 7:44 PM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Lo-Fi Version | Time is now: November 23rd, 2024 - 7:57 AM |
